Key question
Old Jan 17, 2014 | 11:51 AM
DRAFT1's Avatar
DRAFT1
Default Key question
Besides obtaining a key blank with the correct (1-15) value code and having it cut, is there any procedure you have to go through for the key to work or is it just a matter of inserting it into the ignition and starting the car? Thanks
Old Jan 17, 2014 | 11:53 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Insert and turn. Everything else is 'automatic'.
Old Jan 17, 2014 | 06:20 PM
Cowboy26a's Avatar
Cowboy26a
If the key you are using now works then the system is fine. I wanted a spare key to hide under the car in case I lost mine. I measured the resistance, ordered the correct key off Ebay and had it cut locally. Worked perfect. As long as the system on your car is ok, that's all you need to do.
Old Jan 17, 2014 | 06:46 PM
got-20z's Avatar
got-20z
^What everybody else says.
I've done this twice because my car came with 1 key and it was worn to the point that the security light would sometimes come on and it caused me grief in thinking I had some major security/electrical problems.
Old Jan 17, 2014 | 08:13 PM
bighank's Avatar
bighank
Default Fleebay with correct resistor value and a locksmith
If cut correctly and right resistance you are good to go.
Old Jan 18, 2014 | 12:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Keep in mind the key has one side that is a bit different, Make sure you point that out to the place cutting it. 17.99 on eBay.
Old Jan 19, 2014 | 12:17 AM
SG Lou's Avatar
SG Lou
Mr Bill is an ALRIGHT GUY !
To Key question
