Dexcool Question
Old Jan 17, 2014 | 03:50 PM
RHWjr's Avatar
RHWjr
Default Dexcool Question
I'm having my coolant changed tomorrow. The mechanic said he would put in a mixture of 50% Dexcool and 50% water.
Does this mixture sound right? I live in Southern California so it doesn't get cold enough to freeze.
I have had the car stored for a long time and I'm embarrassed to admit I don't think the coolant has ever been replaced (the car is a 2002). I hope I didn't screw anything up by waiting so long to change it.
Old Jan 17, 2014 | 03:58 PM
corvettebob1's Avatar
corvettebob1
50/50 is factory fill so your good, just make sure he uses distilled water and not tap water.
Old Jan 17, 2014 | 06:05 PM
RHWjr's Avatar
RHWjr
Is distilled water used because it has less minerals?
What bad happens if he uses tap water?
Old Jan 17, 2014 | 06:07 PM
RHWjr's Avatar
RHWjr
If the Dexcool comes out clumpy, what should he do? Keep flushing it?
Old Jan 17, 2014 | 06:18 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Keep flushing. That's one of the reasons I dislike dexcool
Old Jan 17, 2014 | 06:30 PM
BAKnBLK2010's Avatar
BAKnBLK2010
Don't put the Dex Cool back in. Go with good old fashion green anti freeze......
Old Jan 17, 2014 | 07:05 PM
RHWjr's Avatar
RHWjr
I'm normally on top of car maintenance. This is the first car that I've had that is more toy than car to me. I've never driven it with the top up. I've got to stay on top of it in the future.
Old Jan 17, 2014 | 07:23 PM
BAKnBLK2010
Originally Posted by 8VETTE7
Only after you have completely flushed ALL traces of the Dex-Cool from the cooling system. If you leave traces of the Dex-Cool then you WILL have the same problem again once you add the "green" stuff. Many if not most non-Dex-Cool coolants are NOT compatible with Dex-Cool.
I agree 100%
Old Jan 17, 2014 | 07:38 PM
Fcar 98's Avatar
Fcar 98
I agree that dex-cool was a problem. it was bad in mid 90's. With this car i flush every 5 years and have not had a problem.
Old Jan 17, 2014 | 07:55 PM
TGO's Avatar
TGO
And in reality it has nothing to do with the dexcool and everything to do with the stop leak pellets GM dumped in the radiators before leaving the factory.
Old Jan 17, 2014 | 08:07 PM
bighank's Avatar
bighank
Default Flush with a hose and tap water with engine running
I flushed the whole system with a garden hose connected to a heater hose after first draining the system. Kept the radiator petcock open and ran the engine. Did this until the water coming out any hole was clear.
Had to close the radiator petcock and let the car fill and come up to temp to open the thermostat and then more coolant will drain from the block. After about 20 minutes running the hose and draining with engine running and clear water coming out shut off engine and let as much water drain as possible. Did remove the gas bottle to do this and tried cleaning as much gunk out of it as possible.
Filled with about 7 quarts of full strength Dexcool and topped off with tap water. Some of the flushing tap water will stay in the system so you add the full strength Dexcool and them add more water. Have NEVER had to use distilled water as the water supply in every place I have lived is not so harsh as to cause a lot of corrosion in the system.
First time I did this the Dexcool mixture was really murky and brown. Next time about 40K later the coolant looked normal. Don't believe the 5 year 100000 mile stuff. 5 years might be OK but not 100K.
Old Jan 17, 2014 | 08:09 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I use Dexcool in my 2002 Vette and the 1998 WS6 and have never had an issue with it, When it comes time to change them Dexcool will be going back in them. I would say that most of the people that have issues with Dexcool was self inflicted. We also have a 2002 Tahoe with Dexcool, Again no issues.
Old Jan 17, 2014 | 08:44 PM
Fcar 98's Avatar
Fcar 98
:i
Old Jan 17, 2014 | 08:53 PM
Fcar 98's Avatar
Fcar 98
96 impala, the dex-cool was like jello when it was drained out had to remove the coolant tank if I remember I replaced it it was so bad. But again no problem with the corvette
Old Jan 17, 2014 | 09:21 PM
50/50 is the recommended mixture.
Old Jan 17, 2014 | 09:31 PM
TGO's Avatar
TGO
Originally Posted by FRANK J CARCIA
:i
Can't fix people derpin' on teh interwebz.
Old Jan 18, 2014 | 12:20 AM
El original's Avatar
El original
Originally Posted by baknblk2010
don't put the dex cool back in. Go with good old fashion green anti freeze......
do not use good old fashioned
green antifreeze...this guy is a nut!!!!!!!!!!!!!!!dexcool ONLY
To Dexcool Question
Old Jan 18, 2014 | 12:34 PM
Loby 1's Avatar
Loby 1
I even replaced over flow tank, thermostate and T stat housing.
There can be no contamination.
Never put green over orange.
Old Jan 18, 2014 | 01:14 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Go read your owners manual. Green is perfectly fine. They say to change it every two years if I remember correctly. Doesn't matter if I run orange, green, or blue, although I didn't like the blue either, they all get changed every 2 or 3 years so it doesn't matter.
Old Jan 18, 2014 | 01:34 PM
thealien's Avatar
thealien
This is what I have been Using instead of Dex Cool
