Possessed C5....WTH
Old Jan 22, 2014 | 09:48 AM
  #41
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
apparently this is an issue on the Chevy Cruze.....found this on a Cruze forum...GM has no idea what the issue is but I am leaning towards the Catalytic converter being the issue.
sounds just like this...loud banging noise
Old Jan 22, 2014 | 09:56 AM
  #42
oldschoolvette's Avatar
oldschoolvette
Originally Posted by VinnyT
Aaaah! Definitely sounds like the cats now. They could be partially clogged causing them to slightly overheat. Once you stop, the temp drops quickly causing the popping noise.
no idea
this sounds possible
Old Jan 22, 2014 | 10:45 AM
  #43
bluestreak63's Avatar
bluestreak63
Yeah, that sounds exhaust related. More specifically, the clasps on the joints where the pipes meet anywhere in the exhaust system. My guess is that they have expanding and contracted enough times from the heat/cool down cycle possibly.
Checks the clamps anywhere on the exhaust system and tighten them up after everything has cooled down and see if it happens again.
Old Jan 22, 2014 | 11:54 AM
  #44
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
it sounds like someone bounced a golfball off the underside when it happens
You don't happen to live next to a golf course, do you?
Old Jan 22, 2014 | 06:41 PM
  #45
zagger's Avatar
zagger
yes we do...but my question for you is did it only do it once or several times as we hear it multiple times for a couple hours after the car is parked.
Thanks for the input
It would do it only once but it was loud pop!
Old Jan 23, 2014 | 12:29 AM
  #46
Choreo's Avatar
Choreo
Catalytic Converter would be my first guess.
Old Jan 23, 2014 | 09:56 AM
  #47
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
When I first started reading my first thought was exhaust somewhere.
Bad cats can do strange things to a car. Things also get loose over the years and just plain go bad on exhaust systems that has no reason to it.
What are the temps running? Higher temps would most definitely lead to a bad cat as a first thing to check.
when something gets hotter than normal and then cools quickly it can cause popping. The temps across the country have been colder than normal and could explain it. Especially if it's in the exhaust system somewhere as I suspect it is.
Old Jan 25, 2014 | 08:56 AM
  #48
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Old Jan 25, 2014 | 10:35 AM
  #49
'Shifter's Avatar
'Shifter
NCM Member '09
Originally Posted by mojo1
Exactly what I was thinking...
Old Jan 25, 2014 | 02:16 PM
  #50
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Several hours? 3, 4, 5? Can't see cats taking several hours to cool off. They make noise but it lessens as time passes and they cool down.
I'm not familiar with the dual tank system but I'm guessing something to do with it
Old Jan 25, 2014 | 10:48 PM
  #51
95wht6spd's Avatar
95wht6spd
Didn't read all, but if from front end, continued thump after car is shut off, could be headlight gear wearing out. My C4 did this, will do it for sometime until eventually headlight wont work at all. Motor keeps turning, doesn't know it is closed. I am guessing the C5 has a similar gear and wears out, maybe not, just a guess.
Old Feb 3, 2014 | 05:29 PM
  #52
psint's Avatar
psint
Default ??
OK....here's the deal. 2002 C5 and the past few months when driving and for a few hours afterwards we get a loud popping/thumping sound coming from the car Nothing has changed, no new mods etc. When driving it sounds like it is coming from the tunnel below the shifter or from behind the dash. It sounds like something is smacking the bottom of the car. Come home and park in the garage and it will do this periodically for several hours. It is random and there is nothing loose under the car that could cause this. We had it on the lift last week and everyone in the shop heard it but no ideas where it is coming from.
Thoughts? suggestions? dumb answers?
see video added in post #41
Remove the cat....
Old Feb 8, 2014 | 09:22 AM
  #53
mojo1's Avatar
mojo1
well???????????????????????????????????? ?????
Old Feb 8, 2014 | 11:41 AM
  #54
'Shifter's Avatar
'Shifter
NCM Member '09
Maybe the spirit exited the Corvette, and has possessed him!
Old Feb 8, 2014 | 09:07 PM
  #55
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Transmission?
Helz, everyone else is guessing.
Old Feb 8, 2014 | 11:30 PM
  #56
zagger's Avatar
zagger
I retract my other post, figured it out!
It's the ex trying to get out of the trunk!
Old Feb 9, 2014 | 09:49 PM
  #57
cobra3's Avatar
cobra3
Default noise
Are you running the a/c while driving , long shot but could be the a/c drain dripping on the exhaust and causing the popping noise.
