Corsa mufflers only?
Old Jan 26, 2014 | 11:17 AM
John4cam's Avatar
John4cam
Default Corsa mufflers only?
Hello all.
I will be receiving my first c5 in a few weeks. Car currently has z06 mufflers installed in an obx kit. I'd like to go with either corsa sport or extreme and I was wondering if you have to buy the complete axle back kit or is it possible to buy just mufflers? I've been searching online with no luck. Thanks.
Old Jan 26, 2014 | 11:22 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by John4cam
Hello all.
I can't answer your question, although I believe you'd have to buy the whole thing, but you might find that you'd have problems trying to weld steel mufflers onto titanium.
Old Jan 26, 2014 | 11:35 AM
jrose7004's Avatar
jrose7004
I would buy the whole catback as the ZO6 catback is titanium and the Corsa's are not.
Old Jan 26, 2014 | 12:20 PM
momo20's Avatar
momo20
you have to buy the whole kit as I am pretty sure you cant just buy the mufflers by them selves
Old Jan 26, 2014 | 12:25 PM
John4cam's Avatar
John4cam
It was actually just z06 mufflers into an obx setup. I'm assuming the obx stuff is stainless like the corsa.
I'm thinking this may be true from recent searches. Thanks.
Old Jan 26, 2014 | 01:34 PM
85corvettec4's Avatar
85corvettec4
alot of corsa kits come with the axle over tubes seperate from the cans so give their offices a call and see what you can get
Old Jan 26, 2014 | 02:40 PM
John4cam's Avatar
John4cam
Thanks.
Old Jan 26, 2014 | 03:40 PM
robert miller's Avatar
robert miller
100% correct here not one of the vendors are mfg will sell you just the mufflers by themself. Ask me how I know.
Old Jan 26, 2014 | 04:46 PM
John4cam's Avatar
John4cam
Lol,
Thanks for all the quick input fellas. I'll make a call to corsa and more than likely they will tell me what I don't want to hear.
Old Jan 26, 2014 | 07:09 PM
dba4life's Avatar
dba4life
I tried to get just the over the axle pipes for Corsa's and could not. Had to buy the entire package.
Ended up cutting a stock exhaust and welding
Old Jan 26, 2014 | 10:22 PM
85corvettec4
give borla a ring while you're looking up numbers
Old Jan 26, 2014 | 10:29 PM
rob-cyn's Avatar
rob-cyn
Corsa is all I would consider unless you like resonance.
Old Jan 27, 2014 | 07:12 AM
John4cam's Avatar
John4cam
No thanks. I'll stick with what's on there before I do that.
Old Jan 27, 2014 | 08:46 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
i also suggest adding a Corsa X-pipe to complete the system and eliminate the motor boat idle sound.
Old Jan 27, 2014 | 10:55 AM
John4cam's Avatar
John4cam
I believe the car has an x pipe on it currently. Does make a huge difference.
To Corsa mufflers only?
