Jacking pucks
Old Feb 3, 2014 | 08:21 AM
guido7834's Avatar
guido7834
Default Jacking pucks
I just purchased the plastic c5 jacking pucks and when installing them, two of them broke when snapping into the hole. Has this happened to anyone else? What overpriced junk. I'll be sending them back!
Old Feb 3, 2014 | 08:46 AM
Derf's Avatar
Derf
I installed them on my last two Vettes. Never a problem and easy to install.
Old Feb 3, 2014 | 08:56 AM
CactusCat's Avatar
CactusCat
Wow, sorry. I contacted my local youth hockey association and they gave me 8 old hockey pucks. I then went to Home Depot and bought some 1-1/2" lag bolts with eyelets like these ( http://www.boltdepot.com/Wire_eye_lags.aspx ) then cut them off with a dremel tool so they wouldn't be too long. I drilled a small hole in the center of each puck and then just screwed them in. Worked perfectly and have about $3 invested.
Old Feb 3, 2014 | 10:13 AM
Corvette_Ed's Avatar
Corvette_Ed
They might have been damaged in shipping. Contact the vendor and ask for replacements. Normally these are very durable; I put mine to the test almost weekly when I pull my wheels to clean the barrels and fender wells.
Old Feb 3, 2014 | 03:32 PM
guido7834's Avatar
guido7834
I made those for use here. Thought the permanent ones would be good for on a lift.
Old Feb 3, 2014 | 03:33 PM
guido7834's Avatar
guido7834
I contacted the vendor. Said "sometimes one breaks but not usually two." I'm getting a refund. overpriced plastic anyway.
Old Feb 3, 2014 | 04:38 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Easy to make nice sturdy ones with a couple of hockey pucks, a drill and an eye-bolt. Cheap, very durable and work great! Zuti
(oops, sorry for the repeat, just saw the post above! But they do work well!)
Old Feb 3, 2014 | 04:58 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I have never had an issue with them. You put them in wrong, admit it.
Old Feb 3, 2014 | 08:09 PM
guido7834's Avatar
guido7834
No, just pushed them into the slot. Pretty simple, wish guy.
Old Feb 3, 2014 | 11:31 PM
Would be nice to know what particular jacking pucks you bought. I have run the BMW pucks in my last two C5s and never any problems with them.
Old Feb 4, 2014 | 06:15 AM
guido7834's Avatar
guido7834
Not the BMW ones.
Old Feb 4, 2014 | 08:43 AM
bjones7131's Avatar
bjones7131
Default Jacking Pucks
Not the BMW ones.
I use round pieces of wood I got at home depot or a wood working craftsman store. I don't attach them to the car, just put them in my jack when needed. They work great. I keep one in the car and one in my shop.
Old Feb 4, 2014 | 10:20 AM
Corvette_Ed
I guess it's just a matter of opinion. Mine have more than made up for what I paid for them.
Old Feb 4, 2014 | 05:14 PM
1powdercoater's Avatar
1powdercoater
Default Puck/Jack
I've shown this before but I had my machinist friend modify these pucks and now they slip right into my jack stands
Old Feb 4, 2014 | 07:07 PM
guido7834's Avatar
guido7834
I just wanted ones to stay on the car for when it goes on a lift at a shop.
Old Feb 5, 2014 | 11:57 AM
bighank's Avatar
bighank
Default My REAL hockey pucks, eyebolts and nuts are in the left rear storage compartment
Made them from real hockey pucks, eye bolts and nuts and store them in the left rear compartment in the trunk. If needed away from home take only a minute to install. Total cost including buying new hockey pucks and eye bolts was less than $10
Old Feb 5, 2014 | 12:37 PM
tentuna's Avatar
tentuna
Yeap, same solution and cost. Could convert them to permanent, but why do it?
To Jacking pucks
Old Feb 5, 2014 | 01:46 PM
vettestream's Avatar
vettestream
Not sure what brand you purchased, but they don't sound very good. I just walked into my local BMW dealer and picked up a set, they have been on the car for years and never had an issue.
Old Feb 6, 2014 | 06:47 AM
guido7834's Avatar
guido7834
Is there a part number for ones that fit the c5? I've seen several BMW types online.
Old Feb 6, 2014 | 07:04 AM
quick89's Avatar
quick89
Two of mine also broke being installed, two just snapped right in
