fuel gauge question
Old Feb 10, 2014 | 12:52 PM
20roadking11's Avatar
20roadking11
Default fuel gauge question
I have a 2002 coupe. The needle on the fuel gauge shows no fuel & the DIC states low fuel level. I've got over half a tank. Any input greatly appreciated.
Wayne
Old Feb 10, 2014 | 01:40 PM
bj1k's Avatar
bj1k
Wayne
Do a search on using Techron in the fuel.
Old Feb 10, 2014 | 01:46 PM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Techron
Old Feb 10, 2014 | 03:03 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Very common issue. Techron worked for me after a few applications. Zuti
Old Feb 10, 2014 | 03:25 PM
20roadking11
Thanks for the info. Anybody else?
Wayne
Old Feb 10, 2014 | 03:38 PM
red03vette's Avatar
red03vette
my fuel gauge was acting strange too, i used GM's fuel system cleaner. they have two, i used the stronger more expensive one. seemed to work real good, haven't had any problems since. i would have used techron but we can't get it anymore up here in Canada. if you do a search there is a number of issue's that can happen with the fuel senders and the jet siphon pump. good luck
Old Feb 10, 2014 | 03:41 PM
kgie1217's Avatar
kgie1217
St. Jude Donor '14
I had the exact same issue about 2 months ago. I ran two bottles of Techron through the system. Everything seems to be working pretty good now. It's definitely a cheaper alternative than replacing the fuel sensors.
Old Feb 10, 2014 | 03:43 PM
DA1984VETTE's Avatar
DA1984VETTE
I was doing the Techron when the tank was empty. I was then told to add it a half tank and then fill it up. I did this and have not had a problem since. Good advice from above..
Old Feb 10, 2014 | 04:04 PM
20roadking11
Thanks for the explanations. Now I know why. Thanks to everyone. I appreciate y'all.
Wayne
Old Feb 10, 2014 | 10:50 PM
Originally Posted by 8VETTE7
You could replace the fuel level sensors in both tanks since that is what the problem is. ie corrosion buildup on the sensors. Techron (large bottle) added to a less than half full tank of fuel and then fill the tank usually solves the problem a lot less expensively than new sensors. Sometimes it takes a few retreats to get the sensors cleaned up and then once a year when you change the oil add another large bottle of Techron to a less than half full tank of fuel and fill it up.
Try the Techron first.
Old Feb 10, 2014 | 11:42 PM
Soundclown's Avatar
Soundclown
I use a bottle of Techron every 3rd tank of fuel. It's not a pricey safeguard.
Old Feb 11, 2014 | 11:05 AM
dadaroo's Avatar
dadaroo
If you end up deciding to replace the senders make sure you get the later model AC Delco MU 1218 (updated P/N from MU1004) for the passenger side. it uses 3 wires and not 4 like the 97-98 did. Don't remember if the driver side changed, not at home now. Let us know how things go.
I worked with a guy in Germany a long time back who kept ordering the wrong right side sender (vendor said it SHOULD work) for his earlier car and just couldn't figure out how to make things work until we FINALLY had him order the CORRECT sender.
Old Feb 11, 2014 | 12:51 PM
Groveman's Avatar
Groveman
I've had the fuel gauge problem 4 times on my 1999 coupe. Mine would usually read half full after I filled up then slowly creep up to full. Techron solved the problem 3 times. On one occasion my fuel gauge read empty on a full tank and wouldn't budge. I tried the Techron again and nothing happened. I tried a second time at the next fill up and still nothing. I then went into the codes and had a fuel code (can't remember exactly which one), I reset it and the fuel gauge worked properly again.
Old Feb 11, 2014 | 02:20 PM
jcgunn's Avatar
jcgunn
Pull the codes from the DIC. This will help diagnose the problem. Look for these:
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P1431 Fuel Level Sensor 2 Performance
DTC P1432 Fuel Level Sensor 2 Circuit Low Voltage
DTC P1433 Fuel Level Sensor 2 Circuit High Voltage
Old Feb 12, 2014 | 12:26 AM
CaliforniaJack's Avatar
CaliforniaJack
Default Techron is in Chevron and Texaco gas
If you're near a Chevron or Texaco (same gas) station, start using their gas for a few tanks. I always use Chevron because it has Techron already in it. If you are having fuel level problems, you might need to use a few bottles of concentrate to clean up the existing Sulphur deposits, but just using Chevron or Texaco on a regular basis will keep your fuel sensors clean without the need to add extra Techron.
Old Feb 12, 2014 | 07:00 PM
20roadking11
I luv this forum! A big THANKS to everyone!
Wayne
Old Feb 13, 2014 | 08:35 PM
Ron222's Avatar
Ron222
Like everyone else here "TECHRON" is the way to go. Also make sure to use a Top Tier Fuel like, guess what? Chevron with "TECHRON".
http://www.toptiergas.com/
To fuel gauge question
