When to change plugs?
Old Feb 10, 2014 | 04:51 PM
bop's Avatar
bop
Default When to change plugs?
Have a 99 with 23k miles and nothing on the car has been changed with the exception of tires-oil-and air filter. Car runs fine but if plugs and wires were replaced would I be able to tell a difference.
Old Feb 10, 2014 | 05:43 PM
JR-01's Avatar
JR-01
I doubt it.
Old Feb 10, 2014 | 05:49 PM
Chicago1's Avatar
Chicago1
Your wallet will be lighter so that's less weight in the car and you may feel a difference in acceleration,,jk..don't waste your money...It being a 99 with 23k I would be more worried about why you don't drive it more often..
Old Feb 10, 2014 | 06:08 PM
bop's Avatar
bop
It was 12 years old and only 14k on it when I bought it. I have a 71 also and am 68 years old and at that age these cars are not as easy to get in and out of as they were when I was 30. It is still a lot of fun to drive
Old Feb 10, 2014 | 06:09 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
If they are the original iridium plugs (which it sounds like the are) they are good for 100 miles. My only issue with time and miles on the aluminum block is that the plugs tend to "weld" themselves to the block after that amount of time making it difficult to remove them, not impossible by any means, but just a bitch.
rr
Old Feb 10, 2014 | 07:26 PM
torchredmadness's Avatar
torchredmadness
You should be good for 100,000 miles.
Old Feb 10, 2014 | 10:20 PM
If you want to just see what the plugs look like, pull a couple and check the condition. If nice and clean, I wouldn't worry about them at this point.
Old Feb 11, 2014 | 11:12 AM
dadaroo's Avatar
dadaroo
rr
If this concerns you, you could pull them now and use some anti-seize on the threads. Otherwise I agree you should be fine. Checking one or two easy to access plugs would not be bad either. Of course as Murphy goes, the hard to get to plugs are always a PITA. Never fails to be the case.
Old Feb 11, 2014 | 07:04 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't know all of the years of C-5s that were affected, but some of the cars had plugs whose "pucks" on the side electrode would pop off, and wind up who knows where. Because of this situation, I changed out the plugs on my '01 when it had about 4-5,000 miles.
To When to change plugs?
