Need a new battery
Thank you
Die Hard Platinum P4
http://www.sears.com/diehard-platinu...2&AID=11042411
Video 1 (Mainly battery discussion)
http://vettetube.com/view_video.php?...a#.Ut5jKk0o6M9
Video 2 (Mainly Column Lock design)
http://www.vettetube.com/view_video....9#.Ut5nPE0o6M8
With that said if you install yourself (and I recommend that) always remove the negative terminal first and reinstall it last. The reason is safety and it is the same thing for all cars. If you remove the positive able first there is chance you could ground the connection with the wrench and cause a problem. There is a torque for the bolts but almost no one has the correct tool and torque wrench to do this. I do, but I still do it by feel. Having worked on cars for 50 years there are only certain critical things I torque. Make sure the battery is fully charged before installing. The store should be able to do this or at least verify it has at least 12.5 volts.
Battery Sizes and option Per Interstate Battery Site: Most likely can be mixed between the years.. size looks to be about the same, some have more CCA then others and they do have a AGM. The Number is the "Battery Group" (Size). My guess is that you can swap in a larger batter with little to no work. I would Recommend a good AGM battery, they dont leak acid if they crack or fail like a normal battery. I like interstate myself but there are others that are good. From what i remember i think you can put a Group 78 in place of a 75 amd vice versa.
Battery sizes stock for C5 Corvette's by year:
2004 MTP-86 640CCA
2003 MTP-75 700CCA
2002 MTP-75 700CCA
2001 MTP-75 700CCA
2000 MTP-78 800CCA -Alternate/Optional MT-75 700CCA
2000 MT7-78 800CCA -AGM
1999 MTP-78 800CCA -Alternate/Optional MT-75 700CCA
1999 MT7-78 800CCA -AGM
1998 MTP-78 800CCA -Alternate/Optional MT-75 700CCA
1998 MT7-78 800CCA -AGM
1997 MTP-78 800CCA -Alternate/Optional MT-75 700CCA
1997 MT7-78 800CCA -AGM
* AGM (absorbed glass mat) recommended for high-accessory-load vehicles including frequent plug-in use. 48 Month Free Replacement
* Mega-Tron Plus Longest life in cold to moderate climates. 30 Month Free Replacement Six Year Performance Warranty
* Mega-Tron II Longest life in hot to moderate climates. 24 Month Free Replacement Five Year Performance Warranty
Battery Size index:
http://www.rtpnet.org/teaa/bcigroup.html
In Inches Length x Width x Height
Group 75: 9 1/16....7 1/16...7 11/16
Group 78: 10 1/4....7 1/16...7 11/16
Group 86: 9 1/16....6 13/16..8
Hope this helps
2004 MTP-86 640CCA
2003 MTP-75 700CCA
2002 MTP-75 700CCA
2001 MTP-75 700CCA
Battery Size index:
Hope this helps
http://forums.corvetteforum.com/c5-t...1999-c5-2.html
S
