[Z06] Blower Cam expert, your advice
Old Feb 14, 2014 | 05:43 PM
Hectorls1's Avatar
Hectorls1
Default Blower Cam expert, your advice
Specs. 2001 z06 74,000 with A&A V2 and billy boat exhaust. Since I'll be doing fluid changes. I was thinking of putting a blower cam with components. Which cam is good for hp and not make my MPG take a nose dive ? Also should I change the valves ? Previous owner doesn't know history of car.
Old Feb 14, 2014 | 06:21 PM
RedZMonte's Avatar
RedZMonte
valves should not need replaced. I would look at new springs and retainers when you do a cam. Look at a few venders to see what blower cams they offer, blower/turbo cams are usually mild with little overlap unlike NA setups that use high lift/long duration and more overlap. have heard Brian Tooley is the cam guy on here recently.
LS6 cam is a pretty decent boost cam allready compared to LS1 but there is allways room to improve
S
Old Feb 14, 2014 | 10:24 PM
95wht6spd's Avatar
95wht6spd
A smaller pulley will be less $. Post in the FI section.
Old Feb 15, 2014 | 04:04 PM
PRE-Z06's Avatar
PRE-Z06
Where are you located? A cam with lower overlap won't bleed off as much or loose as much driveability, feel free to call me to discuss details.
Old Feb 15, 2014 | 08:10 PM
Hectorls1's Avatar
Hectorls1
In Austin, TX
Old Feb 15, 2014 | 09:50 PM
coolazhel's Avatar
coolazhel
Cruising
I have a brand new Lingenfelter GT2-3 cam n appropriate springs available for sale. Never Used. I was going to go FI route but changed my mind and went NA. CAM Specs - 207/220 .571/.578 w 1.7 rocker 118.5 CL. If interested, message me. At any rate, good luck n have fun with your build!
Old Feb 16, 2014 | 12:31 PM
Hectorls1's Avatar
Hectorls1
Not sure if there's enough difference between LS6 and GT1 to warrant the extra cost .
GT1 Camshaft 207/220 - .571/.578 Duration
LS6 204/211.525/0.525
Old Feb 16, 2014 | 03:56 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
02+ LS6 cam is your best bet in terms of hp gains but retaining gas mileage.
At the same time I'd have to question the cost factor for the added 10-15hp.
Youre better off with a smaller pulley and tune if youre looking for more ponies
Old Feb 17, 2014 | 04:16 PM
dagon138's Avatar
dagon138
Ask A&A, they sell blower cams and I'm sure they know how each type will behave etc.
Old Feb 17, 2014 | 05:49 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Hectorls1
In Austin, TX
An 02+ cam wouldn't be worth the hassle imo nor the GT2-3, my sleeper cam works well with boost and doesn't cause a dramatic loss in mpg as it doesn't have a lot of overlap. Just keep in mind that naturally any cam is going to use more fuel than stock as it moves more air through the engine and thus requires more fuel, some are less efficient than others though ie large overlap.
To Blower Cam expert, your advice
