MGW Height Reduction - Shift Boot
Old Feb 24, 2014 | 09:11 PM
jmxp69's Avatar
jmxp69
Default MGW Height Reduction - Shift Boot
Hey guys,
I ordered an MGW for my C5 today and searched for information on the reduction in height from stock. Can't seem to locate anything on the MGW site and I found two threads here mentioning 1.8" but the pics in the thread don't work. Need to know so I can order a new shift boot @ Redline.
Does anybody know for sure what the height reduction is?
Thanks in advance,
J
Old Feb 24, 2014 | 10:02 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
Check this thread out...might help.
http://forums.corvetteforum.com/c5-g...ifference.html
Old Feb 24, 2014 | 10:07 PM
El original's Avatar
El original
The MGW shifter height is adjustable but 2 inches would be average reduction I am thinking. Don't panic as you can install the boot without removing the console. I reworked the stock boot by removing the staples on plastic hoop and reinstalling boot about 2 inches lower on hoop. Till it would not pull down on the hoop. Easy
Old Feb 24, 2014 | 10:33 PM
jmxp69's Avatar
jmxp69
Thanks. I think I'll order a 1" shorter boot and lower on the plastic ring as necessary. Appreciate the link and tip.
J
Old Feb 24, 2014 | 11:32 PM
chasboy's Avatar
chasboy
Oldtimer
I have a Redline boot that I got before I shortened my stock shifter 1 3/4". Boot is fine.
Old Feb 24, 2014 | 11:38 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Can you post a picture? I too have an MGW W/C6 **** and am considering redline's C6 shift boot.
Old Feb 25, 2014 | 12:00 AM
FrankLP's Avatar
FrankLP
Miles of Smiles
FWIW I just used my stock boot w/my MGW...love it.
Old Feb 25, 2014 | 12:35 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Here's my MGW shifter with an offset C6 shaft threaded to fit a C5 (Delrin) ****. The shaft was shortened an additional 5/8". A RedlineGoods boot was made 1" shorter than stock, stapled on the stock ring in the original position.
Old Feb 25, 2014 | 11:27 AM
jmxp69's Avatar
jmxp69
I ordered the C5 and C6 shaft for the MGW. For $15, I figured I'd have some options. When you say "offset C6 shaft" what does that mean exactly?
Do you have a link for that shift ****? It looks great!
Thanks for sharing guys. These threads are very helpful figuring out style before opening the wallet.
Old Feb 25, 2014 | 12:02 PM
c5vetteguy's Avatar
c5vetteguy
My MGW shifter is a previous generation than what they're currently selling, if I'm not mistaken. You had the option of a threaded, straight up C5 shaft, or an offset C6 shaft that was keyed for a set screw ****. I got George to send me the offset shaft, but threaded for a C5 ****. The offset (about 1") allows you to move the **** closer or further away from you. You just have a bit more adjustment available than you would if the **** was straight up from the shifter. I have mine offset to about the 7-8 o'clock position, which brings the **** a little closer to me.
I found the **** on fleabay - there are a lot of different styles and sizes there. Do a search on "C5 Corvette delrin shift ****" and you'll have plenty from which to pick.
Old Feb 25, 2014 | 01:09 PM
jmxp69's Avatar
jmxp69
Great, thanks. Found and ordered one.
Old Feb 25, 2014 | 04:55 PM
chasboy's Avatar
chasboy
Oldtimer
Sure, here you go:
Old Mar 11, 2014 | 04:28 PM
jmxp69's Avatar
jmxp69
Did you zip tie the underside of the boot to the bottom of the ****?
Old May 17, 2014 | 02:01 AM
luke87gt's Avatar
luke87gt
Any pictures to go along with this description?
To MGW Height Reduction - Shift Boot
