B+ post
Old Feb 25, 2014 | 01:50 AM
mickey_7106's Avatar
mickey_7106
Default B+ post
does anyone know if i can get an extended one? mine is pushing the limit. (AMP wire and 2 hid power wires not in pic)
Old Feb 25, 2014 | 11:33 AM
dadaroo's Avatar
dadaroo
If you have already planned to replace it then any carbon steel bolt would work. Not sure how it is attached on the underside. Field stripping the Fuse box into it's pieces should tell you.
That or replace the nut with a thinner one. A nut only needs about 1 1/2 threads to develop full strength for the joint. The thinner ones are called Jam Nuts. You can get them everywhere like even Home Depot. Google it and you will see. Mr. Sam, PE
Old Feb 25, 2014 | 02:02 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Or you can splice the other wires into one ringlet to keep down on the number of ringlets going onto the post
To B+ post
