Does anyone know
Old Feb 28, 2014 | 11:12 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Default Does anyone know
I've tried searching, to no avail..
Do the C5-Z06 rear wheels (18" x 10.5") fit over the C6-Z06 front 6-piston caliper/rotor set-up?
Maybe this has been answered, but I couldn't find it.
Old Feb 28, 2014 | 06:27 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Old Feb 28, 2014 | 09:52 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
Yes. There are a number of C6Z guys running square track set-ups with C5Z rear wheels.
Old Feb 28, 2014 | 11:13 PM
'Shifter's Avatar
'Shifter
NCM Member '09
No spacers?
Old Feb 28, 2014 | 11:16 PM
jcsperson's Avatar
jcsperson
No spacers?
No spacers required as long as it's an OEM C5Z 10.5x18 wheel.
Old Mar 1, 2014 | 09:08 AM
hougland's Avatar
hougland
No spacers?
Hey Marc,
You could bolt on one of my stock race wheels for a test fit, what size tire are you thinking about running on the front? And is there room?
https://www.corvetteforum.com/forums...es/cheers2.gif
Old Mar 1, 2014 | 09:49 AM
'Shifter's Avatar
'Shifter
NCM Member '09
I have 4 OE Speedline Z16 wheels, and an extra pair of 18" x 10.5" that I had intended on running (with 2" spacers) on my Z/28, but if they'll fit on the FRC also, maybe I can use them on both cars...
Old Mar 1, 2014 | 09:55 AM
'Shifter's Avatar
'Shifter
NCM Member '09
Originally Posted by hougland
Hey Marc,
Jimbo, are you running Z06 wheels on the track?
I'm going to run the 18" x 10.5"'s all the way around on the Z/28, and I was thinking of doing the same on the FRC..
(On the Z/28, they'll rub the inner fender-wells a little when maxed out)
Old Mar 1, 2014 | 01:08 PM
hougland's Avatar
hougland
Nope, just the stock painted C-5 Wheels, want to stay in stock class. Not sure what you can change & what you can't, and can't figure out how to post questions on the AZ. scca forum. IT SUX!!!!
Would love to run the 18s on the front would probably make me change classes. Did pick up a new pair of BFG G Force KD's yesterday for the front, can't wait to try them out!
Old Mar 1, 2014 | 04:51 PM
'Shifter's Avatar
'Shifter
NCM Member '09
I think, if I read correctly, that you can +1.
Old Mar 2, 2014 | 10:24 AM
hougland's Avatar
hougland
Old Mar 9, 2014 | 04:29 PM
'Shifter's Avatar
'Shifter
NCM Member '09
I've answered my own question. Mounted them up today, and yeah, they clear the diameter of the caliper, but the spokes of the wheel rub the side of the caliper. So yeah, I can use them, but they will require a shim...
Poopy.
To Does anyone know
