[Z06] New tires need help!
Old Mar 5, 2014 | 01:34 PM
bjstrait's Avatar
bjstrait
Cruising
Default New tires need help!
So I'm in the market for some new tires for my stock wheels. Really don't wanna spend the money for the PS2s and seems the only other option in stock sizes are the Bridgestone potenzas. I notice there are many options if you go with 275 up front. Need help deciding here I am mostly using the car for nice weather days and not planning on beating on it at all. Do I go with the potenzas? Are the 275s side walls gonna look funny? Any insight and possible pictures are appreciated, thanks.
Old Mar 5, 2014 | 02:25 PM
quick04Z06's Avatar
quick04Z06
For what it is worth, I had RE050s on my Porsche Cayman S and I thought they were good rubber. Stock Z06 fitment is a pain, but you are only 10 mm large at 275 so I doubt it will be an issue. Perhaps others can chime in.
Old Mar 5, 2014 | 02:31 PM
brownie374's Avatar
brownie374
I have the potenzas;,bought them last summer at discount tore $985.00 installed for 4,much quieter than the goodyears and good bite too,I think the more rounded tire looks good.
Old Mar 5, 2014 | 02:32 PM
MY03C5Z's Avatar
MY03C5Z
275's up front fit just fine, they dont look off at all imo. Running NT05's in 275's up front, 295's in back. Great tire btw, the car is not a dd.
Old Mar 5, 2014 | 03:02 PM
quick04Z06's Avatar
quick04Z06
Just priced Bridgestone S-04s at Tire Rack, 255-40-17f, 285-35-18 rear, 866.93 shipped to my location. I realize this is going smaller, but it sounds pretty good and these tires got great reviews. Stagger seems right, too. I 'd check it out--heck, I may order these.
Thoughts?
Old Mar 5, 2014 | 04:24 PM
troyguitar's Avatar
troyguitar
I like Continental DW as a street tire option for the stock wheels. 275/40/17 and 295/35/18 set is $828 shipped to my house from Tire Rack.
For some reason you get more search results when searching for the front and rear tire sizes separately than searching for them as a set. I don't know why.
Old Mar 5, 2014 | 04:30 PM
RedZMonte's Avatar
RedZMonte
These are the same tires and sizes i run on my 04Z and no complaints. they are good for try/wet but not snow (NO SNOW AT ALL)
S
Old Mar 5, 2014 | 05:08 PM
troyguitar's Avatar
troyguitar
Right. If you drive it in the winter you'll need a separate set of wheels and tires but that is the case with any of these options. You could switch to an all-season compound like the Continental DWS but that seems silly on a Z06 to me. The DWS has significantly less grip in both the dry and wet than the DW all in the name of having some cold/snow traction.
Old Mar 5, 2014 | 05:48 PM
bjstrait's Avatar
bjstrait
Cruising
Anyone have the vredesteins?
Old Mar 5, 2014 | 05:51 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Do a search - my recollection is that pretty much everyone who has tried this tire like them.
Old Mar 5, 2014 | 07:56 PM
Russ K's Avatar
Russ K
Yes, the 275's sidewall is noticeably taller than the 295/35/18. I don't care for that and would stay with a 265 front tire.
Toyo Proxes 1 are available in OEM sizes.
Russ Kemp
Old Mar 5, 2014 | 08:40 PM
540Z28's Avatar
540Z28
Just purchased SP500s and went with Bstones RE-11s. I went with 19x11.5 with 305-30s on the rear and 18x9.5 with 275-35s in the front. Here is my observation. I wish I would have went with 265s. Comparing the look between the front and rear, the tread is wider on the fronts than the rears which give the front a little blockier look. The rears "roll over" from the sidewall to the tread.
Old Mar 5, 2014 | 09:33 PM
Russ K's Avatar
Russ K
What I don't like about the 275/35/18 is the sidewall is noticeably taller than the 305/30/19. I have a 265/35/18 & 305/30/19 tire combo on my car.
Russ Kemp
Old Mar 5, 2014 | 09:58 PM
JBoyle997's Avatar
JBoyle997
I actually Just ordered the Bridgestone Potenza RE760's from Tire Rack.com 756 shipped. 265/40/17 front 295/35/18 rear. Hope I made a good choice. I hear its a great tire for the money.
Old Mar 6, 2014 | 01:43 AM
hmmmm16417's Avatar
hmmmm16417
i just picked up the potenzas 295/35/18 a few weeks ago for $126 each including shipping. (tire hero website) had them installed on the rear but my car is still on the jack stands until the snow is gone. i grabbed two sets because they were such a good deal. the production date is late 2008, but they will serve me fine for daily driving
Old Mar 27, 2014 | 11:37 PM
Paul Semiraro's Avatar
Paul Semiraro
4th Gear
Three weeks ago I put the Bridgestone Potenza RE760 on my 02 Z06. I only drive the car on nice sunny days and so far put about 200 miles on them. They really stick and the car handles great compared to the Toyo tires. I purchased all 4 tires at Discount Tire and out the door price was $779.00. Being a returning customer and a Veteran gave me special discounts that I really appreciated. I highly recommend this tire.
Old Mar 28, 2014 | 12:24 PM
Quickshift_C5's Avatar
Quickshift_C5
Your front tires are fine (and they aren't wider), it's the rears that are the problem. That's because you're using the wrong size wheels for the tire (it accepts it, but that wheel is on the very bottom of the range). The 305's fit fine on an OEM C5Z 10.5 wheel, but you're stretching the tread a bit to get it to fit on a wider 11.5 wheel...which is going to look horrible and probably not functional quite as well since you're deforming the shoulders (the rounded look).
Old Mar 29, 2014 | 03:50 AM
striper's Avatar
striper
Excellent tire and a great price too. Overall excellent ratings. Call Fairmount Tire in L.A., ask for Brad, tell him you're on Corvetteforum. Great service from him. 323-750-2840. Everyone who uses them is very happy.
To New tires need help!
