Do you notice better MPG between brands?
Old Mar 5, 2014 | 05:00 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Default Do you notice better MPG between brands?
My car is an 01 6spd vert and I seem to be getting a full 2 mpg better per tank with Mobil 93 over Shell 93. I do the same mix of driving and the past 4 fill ups with Mobil I've gotten 23 mpg compared to 21 with the past 4 with Shell. I keep track with an app on my iphone and it's pretty consistent what the avg. on the DIC which varies from 22-24 mpg. They're both 93 octane gas so I don't know why I would get better mpg with one over the other.
Old Mar 5, 2014 | 05:34 PM
coia96vette's Avatar
coia96vette
My mpg always depends on my right foot. Too much force on it and the mpgs go down....
Old Mar 5, 2014 | 05:42 PM
ALLEGRO's Avatar
ALLEGRO
The main reason for differences would be the local provider's blend of winter vs. summer gas. The Winter blend generally yields less economy for us consumers, but not always.
As mentioned in the post above, probably your right foot.
Save the Wave
Old Mar 5, 2014 | 05:48 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Well I alternated each fill up over the past year and amazingly not on purpose..my foot stays the same-pretty light unless some punk in a Mustang tries to pass me then it's bye bye...
Old Mar 5, 2014 | 05:56 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I'm not even **** enough to care or keep track on such things. I fill the tank when I need it and where I need it and drive without any concern about my mileage.
Same with my motorhome. I haven't even calculated the mpg because I'm going to drive where I want to go regardless of the mpg or price of fuel.
My commonsensometer would indicate there probably is a difference between some brands but I have no data.
Old Mar 5, 2014 | 08:43 PM
Never really noticed much of a difference between brands. Seems the car gets about the same MPG regardless of the brand.
Old Mar 5, 2014 | 11:05 PM
JaxEagle's Avatar
JaxEagle
im in an 01 6M vert also. I use shell 93 exclusively but we don't even have any Mobil stores in north Florida. Anyway, I don't DD my car so I don't really calculate MPGs. I'd try Mobil to do your experiment if we had stations here
Old Mar 6, 2014 | 07:00 AM
dankhts's Avatar
dankhts
Biggest issue is likely the amount of ethanol in the gas....depending on where you're located and which supplier you use, ethanol content varies .... The more ethanol, the less fuel economy....less ethanol = better fuel economy....some higher octane fuels contain more ethanol as it's a cheap way to add octane....
Around here, Shell 91 is the only premium gas without octane, Petrocan 94 contains 10%.......ethanol content is usually listed right on he pump....
Old Mar 6, 2014 | 09:30 AM
bj1k's Avatar
bj1k
I don't know if they even sell Sunoco in your area , but they do in Pa. and without a doubt it gets the worst gas mileage every time. It seems like they add something to make it burn faster. Most of the others seem close in mileage.
Old Mar 6, 2014 | 11:26 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Do you know if one of them is ethanol free and not the other. If so, you will usually see worse mileage from the one with ethanol.
For a way to find out, take a look at the following link to see what stations are ethanol free in your area.
http://pure-gas.org/index.jsp?stateprov=FL
Old Mar 6, 2014 | 04:31 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Yes I do, as much as 2 mpg.
And they must be doing something with the mix because every one of our cars, the MPG has decreased over the past 2 or 3 years. Again, by 2 to 3 MPG.
Old Mar 6, 2014 | 04:35 PM
envyz06's Avatar
envyz06
I never really notice any difference.
Old Mar 6, 2014 | 05:06 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Originally Posted by QCVette
Do you know if one of them is ethanol free and not the other. If so, you will usually see worse mileage from the one with ethanol. For a way to find out, take a look at the following link to see what stations are ethanol free in your area. http://pure-gas.org/index.jsp?stateprov=FL
It's the same Mobil station I go to but there's about 3 different shell stations in my area, none are on that list. I think both premium gas's say "May contain 10% ethanol" I'm guessing the Mobil may contain less ethanol than the Shell?
Old Mar 6, 2014 | 06:46 PM
paco04's Avatar
paco04
I have not experimented with brands, but I have been determined to use pure gas in everything I own, from lawnmower to boat to car. Can't hurt, I guess.
Old Mar 6, 2014 | 06:51 PM
GoldenFlame's Avatar
GoldenFlame
I did this experiment last winter in my Camaro (which is an LS1). With Sunoco 93 I was getting about 18.9xx MPG. I started using Countrymark 91 Ethanol Free and it jumped to 21.3xx MPG with no change in driving behavior. I didn't do the math though to see if it was cost effective or not.. 93 was about $3.20 and the 91 was about $3.90
Old Mar 6, 2014 | 08:33 PM
memmer's Avatar
memmer
I just found a Chevron station that is pumping Ethanol free 92/110.I haven't
tried it yet as my vette is still in hibernation but you can bet on it that I will as soon as I can.Ethanol can't be all that good for these engines.
Fred
Old Mar 6, 2014 | 08:54 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Not all gas is created equal. Try another brand of 93 and see how it fares.
like mentioned earlier, you need to run the comparisons during the same seasons.
Old Mar 6, 2014 | 09:10 PM
jrose7004's Avatar
jrose7004
I certainly get better MPG with 100% gasoline than 10% alcohol.
Old Mar 6, 2014 | 09:54 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Prolly nailed it! GASSOHOL hurts mileage and equipment! I won't run that crap in my vehicles or equipment engines
To Do you notice better MPG between brands?
