C5 Z06 Half Shaft
Old Mar 10, 2014 | 04:23 PM
Mickman's Avatar
Mickman
Default C5 Z06 Half Shaft
I am getting a lot of clicking noises from my driverside (left) rear wheel area when I move from a complete stop, or going from forward to reverse, etc. I believe I have to replace my half shaft. I am guessing my best bet would be to get a GM part. So my question is.. where would be the best place for me to buy this online and what should I expect to spend?
Any help would be appreciated!
Old Mar 10, 2014 | 05:31 PM
wbrands's Avatar
wbrands
Check the axle nut before buying a half shaft. I was getting a lot of clicking/clunking and it turned out to be this nut. Check it by rocking the car (by rocking the tire with the car on the ground) and listening for a click in the hub area. Tighten nut to 118 foot pounds (I think) and see if that clears the problem. There are threads on the forum about this problem.
Old Mar 10, 2014 | 09:26 PM
Mickman's Avatar
Mickman
I tightened the axel nut and the sound went away for a couple days, but now it is back. Would this lead to thinking its not necessary for me to change the half shaft?
Old Mar 11, 2014 | 08:38 AM
wbrands's Avatar
wbrands
I can't really say for sure, but it sounds like this is still your problem. I have read on the forum where some recommend replacing the axle nut anytime you remove one. You might try that and/or some locktite (not sure what kind but you can probably find recommendations if you search the forum. Also make sure you torque the axle nut (118 ft-lbs IIRC).
Old Mar 11, 2014 | 05:13 PM
paxmanz06's Avatar
paxmanz06
I think it's recommended to replace the nut. I had the ticking sound too on the driver's side and followed this guide to grease the splines: http://forums.corvetteforum.com/1563995880-post32.html
The sound hasn't come back.
To C5 Z06 Half Shaft
