[Z06] Lets talk coil overs...
Which brand to get thats good for just a street driven car?
http://dougrippie.com/products/drm-c...-package-c5c6/
If you want to see how our G2's go on the car, take a look here: http://www.lgmotorsports.com/gallery...20Corvette.pdf
The GT2's were done after that and primarily designed for a street car that might see a few weekends at the road course, or maybe a trip down the strip. They are a single adjustable shock and generally have a softer spring rate than most of the G2 builds (out side of the drag builds of course).
All out dialed in performance, the G2's are going to be your best bet. An all around setup, the GT2's will handle most people's needs.
As for the question on bump stops...depends on the build.
All of the GT2's do have a bump stop built into the shock and you can see it in the build. On the G2's, it depends on the build. Some of them will need a bump stop, and some do not as in many cases you would never see that much bump to the shock unless you are acting out a scene from the Dukes of Hazard, which I don't suggest. The log video was bad enough to do.
Ton more adjustment if you want to completely slam it, but I just had the shop set the ride height close to what it was before...plenty low enough for me. They also corner balanced the car and did a fairly aggressive track alignment. Photo's with street wheel set-up.....18x10.5 speedlines with 295/35/18 rear and 275/35/18 front
That is a darn good looking car!
