Best way to launch?
Old Mar 12, 2014 | 06:08 PM
Wendell Allen's Avatar
Wendell Allen
Default Best way to launch?
Finally got the 2000 and may run into a race or two this week. My cars stock, A4 with Goodyears . Save me the learning curve. What's the best way to launch?
Old Mar 12, 2014 | 06:36 PM
andrec10's Avatar
andrec10
Put some rockets on it, bring it to kennedy space center and light the fuse!
Old Mar 12, 2014 | 06:54 PM
Power Hawk's Avatar
Power Hawk
Leave traction control/active handling on and take about a full second to floor throttle.
Enjoy.
Old Mar 12, 2014 | 07:18 PM
UM Rebel's Avatar
UM Rebel
Set Competitive Driving on. Launch at half throttle against brake. Then WOT. Leave it in Drive. Factory shift will be more consistent than manual shift. Tires and track conditions will dictate how much throttle against brake. Take your first couple of passes to figure that out.
Old Mar 12, 2014 | 07:21 PM
RedZMonte's Avatar
RedZMonte
Hold brake and give it throttle, stock tq converter will only stall up so high. Rev up in 500 rpm increments above idle then +500 each time an try launching and see where your car hooks best. Then try pressing the gas pedal down at different quicknesses, you can feather it faster or slower to keep traction. You can keep traction best finding the sweet spot between how much Rpm's to launch at and how quick to get to WOT, couple try's will get you setup well. Keep in mind each road will react differently I launches... Good pavement will hook better then bad pavement and black top will react different then concrete
Old Mar 13, 2014 | 05:25 PM
calinator's Avatar
calinator
Launch on the street=impossible. 3/10's throttle on 2:73 with Hankooks will spin the tires.
At the track=Floor it right off the line lol. I revved mine to 1,500rpms but I bet not revving it at all would be better. I ran a pretty good time at the track in heat with only 2:73's.
calinator's Avatar
calinator
Oh and 0 spin at the drag strip flooring it off the line my numbers were CONSISTENT!
Old Mar 13, 2014 | 09:26 PM
NukeC5's Avatar
NukeC5
For a near stock car and street tires I always got my best times leaving TC on and stalling it out as best as possible. With sticky tires, TC will only slow you down.
To Best way to launch?
