C5 Corvette-throttle unresponsive
Old Mar 24, 2014 | 06:27 PM
Endeka's Avatar
Endeka
Default C5 Corvette-throttle unresponsive
Hi,
I've posted a couple threads here as I've tried to chase down a problem I'm having. The engine was throwing the "throttle position code" and running on reduced engine power, and running rough like it was on four cylinders or something, intermittently.
I bought a new ignition switch because another owner described the host of electrical problems associated with the failure of that part, and it sounded like my issues to a T.
Well, when I started the car up to do the replacement, a whole new problem cropped up-it still had all the symptoms, but now the car wasn't responding to throttle inputs... at all.
Is it safe to conclude that the throttle body is actually the problem at this point? If so, what's the best route for a replacement for a DIY er?
Old Mar 24, 2014 | 10:38 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Post a new thread in the C5 Tech forum. The guys over there are top notch! I know some basic stuff, mostly mechanical. The Tech bunch are your best bubch to bet on!
Old Mar 25, 2014 | 09:59 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
When mine was unresponsive it was the throttle position sensor that was bad. Not sure if that will fix your rough idle problem though.
Old Mar 25, 2014 | 02:03 PM
jim993's Avatar
jim993
Among many things, a bad ignition switch can cause the reduced power warning and in that instance, the engine will not respond to throttle inputs. My second bad ignition switch did that, but a shutdown and restart resulted in normal engine power, although with a check engine light.
To C5 Corvette-throttle unresponsive
