timing chain questions.
Old Mar 25, 2014 | 12:36 PM
Quintenblackvette's Avatar
Quintenblackvette
Default timing chain questions.
Hi all just a few questions about the timing chain.
I have 117K on my clock and was wondeing when should the timing chain be changed out. How hard of a job is it to do? I have no mods other than a lip and ram Vararam intake and I do no racing. I looked around a little on the internet and could not find anything of worth on changing it. Does anyone have a link with pictures to show how to do this. On a scale of 1-5 how hard is it?
Old Mar 25, 2014 | 01:30 PM
3boystoys's Avatar
3boystoys
Have to pull the steering rack and harmonic balancer, after that it's easy.
Old Mar 25, 2014 | 01:47 PM
Adrians99FRC's Avatar
Adrians99FRC
http://www.ls1howto.com/index.php?article=1
I have 124k on mine and just took it all apart for a cam swap yesterday .. chain has about 1/2" of slop and a couple people ive talked to say thats normal .. so I'd leave it unless you gotta change the balancer
my balancer started wobbling and throwing belts so I'm going ahead and doing a blower cam, timing chain, water pump, oil pump, etc while its all apart
its not that bad of a job, just a bunch of stuff to take out
Old Mar 25, 2014 | 03:32 PM
Quintenblackvette
Default reply.
Wow looked at that link and that looks like a big mod. How big of a diffrence is it from stock? I'm not to sure I want to do anything like that, not a big go fast kind of guy, More power to you though!!!!!!!!!!!!!
Gota show those stangs out there who's boss. Mine does not have any play in the harmonic balencer that I am aware of. Just changed the all the belts and they are on. If it is wobbling what should i look/listen for? Just dont want to throw a timing chain and ruin my car. Again I have no major mods.
Old Mar 25, 2014 | 03:36 PM
Adrians99FRC
you wouldnt use all the steps in that how to .. just the part for taking stuff off to get the steering rack out and the balancer off
it'll make the belt chirp and eventually throw a belt .. all the stock ones eventually come apart, but mine probably came apart faster b/c of the supercharger
your timing chain is fine .. I wouldnt change it unless you had the car apart already for something else .. theres people on here that have over 200k on a stock motor
Old Mar 25, 2014 | 06:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
With that many miles, I'd be looking REALLY close at your harmonic balancer. If it looks suspicious in any way, I'd swap it out, and since you're into it that far, at that point, the timing chain wouldn't be all that much more work.
Old Mar 26, 2014 | 05:03 PM
Quintenblackvette
Default reply.
Hey thanks, yea I think it will be okay. Quick question, can you see the harmonic balencer wobble if it is going bad? So far I have no plans to tear into to it, should it all be okay though? Also If it throws a belt is that a sighn that the chain needs replaced imediatly? I just changed the belts and they are all on fine.
Old Mar 26, 2014 | 05:14 PM
robert miller's Avatar
robert miller
No on the question on the chain being bad if the balancer is wobble. But most of these guys in here are F/I on the motor and this stock balancer don't like that high RPM. It just wasn't made to take it for that long of time with a blower or turbo on the car.
Old Mar 26, 2014 | 05:38 PM
Adrians99FRC
you can see it wobble if you get a good flashlight and look down at it from the drivers side .. well actually probably both sides on yours .. I got a supercharger blocking my passenger side view
it will start making a chirping / squeeling noise and eventually start chewing belts up .. that has to do with the balancer, nothing to do with the timing chain
Old Mar 26, 2014 | 05:39 PM
Quintenblackvette
Default reply.
My engine is all stock. It has 117k on it, if the harmonic balencer is bad will it always throw belts?
Old Mar 26, 2014 | 06:00 PM
Quintenblackvette
Default reply.
Do you know anything on the timing chains on the ls1? If they have to be replaced? I'm not a super experienced mechanic. I would try replacing the H/B though. It might be a month or so before I can do the job is that something to worry about?. I’ve changed out plugs, wires shocks, belts and fluids on the car by myself before so I know I can do that.
Digging far into the engine however makes me nervous, that’s why I’m cautious about doing the chain. I think I might have slight wobble, my eye is untrained though. The engine squeaks sometimes but I know that’s from the ac belt which is going to be replaced soon. So far the belt runs on track fine. But if the balancer was on its way out it would start to eat the belt and thats how I know to replace the H/B?
Old Mar 26, 2014 | 06:09 PM
robert miller
If the bal is good let it go. The timing chain with replacement back to a stock one that would be easy enough also. But the oil pump in these cars you need to use a gauge to have x amount of space between the gears in the pump after it is bolted up. And if that is not correct you will have problems by my understanding.
Old Mar 26, 2014 | 06:28 PM
Quintenblackvette
Default getting back to you.
Okay I will but so far the belt runs on track fine. But if the balancer was on its way out it would start to eat the belt and thats how I know to replace the H/B? I just want to do preventive maintenance to keep the car on the road.
Old Mar 26, 2014 | 07:36 PM
Quintenblackvette
Default reply.
I think it is good, but to be clear if it was starting to go bad it would chew up belts or throw them? Also I have not had problems with my oil pump. That is located on the back of the ls1?
Old Mar 27, 2014 | 08:07 AM
leadfoot4's Avatar
leadfoot4
Technically, I believe you're correct, as I saw a build-up pictorial in an aftermarket book, that went through a series of measurements, when installing the oil pump. Then I looked through the factory shop manual, and it essentially said, "Carefully slip oil pump in place".....
When I replaced my balancer, last year, I figured "what the hell", and replaced the chain with the newer LS2 chain. Naturally, I had to remove the oil pump. When reinstalling it, I honestly couldn't see how you'd "adjust" it's position on the engine, since several pretty snug fitting bolts hold it in position. Secondly, the other book I looked at said to use something like 0.003" shim stock.
First of all, I didn't have any on hand, and since I retired a few years back, I couldn't "borrow" a piece from my employer's tool room. Secondly, .003", that's about the diameter of a human hair, if not a little less. How are you going to go about getting something like that in and out of the pump, with the engine in the car?
To timing chain questions.
