Battery Life
Old Apr 8, 2014 | 10:28 PM
corvette77's Avatar
corvette77
Default Battery Life
What kind of battery life are other getting? Since buying my coupe in 2008, I have had to replace the battery every 2 years. I have been using an AC Delco every time, and the car is a daily driver, so I do not charge it.
Old Apr 8, 2014 | 10:34 PM
chuckeb84's Avatar
chuckeb84
Nice car color
My battery is a sears AGM 1 year old.
Stored and on charge over winter with battery tender.
Heat in Texas may be a problem
Old Apr 8, 2014 | 10:48 PM
My first Red Top lasted 7+ years and was still going strong when I sold the car.
When I bought my current C5, it had a Red Top in the car - it lasted about 37 months and died.
Replaced it with the Sears DieHard Platinum that is now in the car and it has been chugging along for 3.5 years with no problems.
Old Apr 9, 2014 | 07:51 AM
4 KRUSIN's Avatar
4 KRUSIN
Optima Yellow Top. Just starting its 9th year.
Old Apr 9, 2014 | 08:26 AM
kjohnson's Avatar
kjohnson
Just replaced the dynacell that was in my car when I bought it.sticker said June 09 when installed.
Old Apr 9, 2014 | 08:54 AM
jrose7004's Avatar
jrose7004
My 04 has had 2 batteries in it's life. The original Delco and 1 Red Top about 2 years ago.
Old Apr 9, 2014 | 09:09 AM
vettestream's Avatar
vettestream
I believe I am on my 5th or 6th year with my red top, I lost track.
I thought it Finally gave out a week ago, as it had been on a battery tender since August, but I drove the car around for about an hour and now it's doing fine.
Old Apr 9, 2014 | 09:15 AM
3boystoys's Avatar
3boystoys
My redtop is 8 or 9 years old, always keep ALL my toys on float chargers. My motorcycle battery is probably 7 years old now.
Old Apr 9, 2014 | 10:47 AM
CQRT's Avatar
CQRT
A lot depends on how much you use AC, if you have some aftermarket accessories like stereo that create draw and your climate.
Here in AZ, I can figure on replacing car batteries every 2-3 years regardless of brand.
Old Apr 9, 2014 | 12:45 PM
Lee DeRaud's Avatar
Lee DeRaud
Not surprising in that heat. The question is, does it go through batteries faster than your other cars?
I would expect, for daily drivers at least, that battery life would be about the same as most other (relatively) modern cars. The ones that stayed parked for weeks at a time, I have no idea: never had a car like that.
Old Apr 9, 2014 | 10:50 PM
lfj2025's Avatar
lfj2025
I changed factory battery after 8 years just as a precaution.
Old Apr 10, 2014 | 03:40 PM
Last C5's Avatar
Last C5
My 2004 convertible is on the charger over the winter and when not being driven.
I changed out the factory battery this year since it was getting weak.
I put in a Sears Platinum AGM, hope it will last 10 years too.
Old Apr 10, 2014 | 04:53 PM
Phanni's Avatar
Phanni
I've had two red tops, neither lasted over one summer.
I now have Delco in both Vettes, going on at least 3 years.
Old Apr 10, 2014 | 05:12 PM
EscapePod's Avatar
EscapePod
I've had 4 batteries in my 2001 (Central FL). Had to replace every 2 years (even the Optima Red Top). Finally, put in a DieHard Platinum (first battery I ever paid over $200 in my life). It has been working fine, and going on its 8th year.
Old Apr 10, 2014 | 09:34 PM
corvette77's Avatar
corvette77
Thanks for the replies, maybe I have just been getting some bad batches. Good thing is that the last two have been covered under warranty.
Old Apr 11, 2014 | 10:00 AM
bj1k's Avatar
bj1k
You can't beat Sears DieHard batteries. I've used them in all of my vehicles for many years including my truck which runs an electric winch on my car hauler and a crane with electric over hydraulic which pulls a lot of power and I average 7 to 8 years on those batteries.
To Battery Life
