[Z06] Wheel and Offset Question!
Old Apr 12, 2014 | 03:13 PM
LandFill's Avatar
LandFill
Default Wheel and Offset Question!
Hey everyone!
I am purchasing a 2002 TT Z06 on Wednesday , and I am planning on buying a set of the C6 Z06 wheels to put on her.
My question for everyone is this:
The Z currently has brand new tires on the aftermarket wheels that are on it. The tires are 275 front and 295 rear and the wheels are 18/19, respectively. I want to get 18X9.5 front and 19X11 rear. However they have two options available for the offset. Which offset should I get for the fronts and the rears?
What is available for the fronts: 18X9.5 +40 and 18X9.5 +57
What is available for the rears: 19X11 +64 and 19X11 +79
Thank you for your time!
-Phil
Old Apr 12, 2014 | 07:37 PM
ZeeOSix's Avatar
ZeeOSix
fronts: 18X9.5 +57
Outer lip of the wheel will be only 3.0 mm inward compared to OEM Z06 wheels
rears: 19X11 +64
Outer lip of the wheel will be only 0.3 mm outward compared to OEM Z06 wheels
fronts: 18X9.5 +40
Outer lip of the wheel will be only 14.0 mm outward compared to OEM Z06 wheels - TOO MUCH OUTWARD
rears: 19X11 +79
Outer lip of the wheel will be only 14.7 mm inward compared to OEM Z06 wheels - TOO MUCH INWARD
So, the 18X9.5 +57 fronts and 19X11 +64 rears would definately be the best setup.
Old Apr 13, 2014 | 02:14 PM
LandFill's Avatar
LandFill
Originally Posted by ZeeOSix
fronts: 18X9.5 +57
rears: 19X11 +64
fronts: 18X9.5 +40
rears: 19X11 +79
Thanks so much! I really appreciate you writing all that up for me!
Old Apr 13, 2014 | 04:00 PM
ZeeOSix's Avatar
ZeeOSix
Post up some photos when you get the new wheels & tires on your ride.
To Wheel and Offset Question!
