C5 DRL Replacement
Old Apr 18, 2014 | 04:22 PM
gary583's Avatar
gary583
3rd Gear
Default C5 DRL Replacement
Is it easier to replace the DRLs by removing the headlights or by going underneath the car?
Old Apr 18, 2014 | 04:28 PM
kabluie's Avatar
kabluie
A guy named Junkman (Youtube video) says that it's easiest to go through the front brake cooling ports.
Old Apr 18, 2014 | 04:44 PM
avigar's Avatar
avigar
Have you considered disabling them? I did. The heat generated by the bulbs can melt part of the plastic housing right above them. This can start to let moisture inside the housing. You'll still retain parking and turn signal functions if you mod the relay located inside the passenger foot-well area.
Follow the link below for the how to:
http://forums.corvetteforum.com/c5-g...questions.html
Old Apr 18, 2014 | 05:09 PM
JR-01's Avatar
JR-01
Simply remove #2 fuse to disable running lights. The signal lights will not flash when you use fob to unlock but, front turn signals will operate normally.
Old Apr 18, 2014 | 05:32 PM
Phanni's Avatar
Phanni
Why disable them?
Just put in HID bulbs/ ballast, and use as intended.
If you have big hands and arms, go through the bottom, just remove the inner fender piece.
Old Apr 19, 2014 | 05:46 PM
I took the access panel under the front end off when I swapped mine out. Probably a little more work, but no problem with access once the panel is off.
Old Apr 19, 2014 | 06:01 PM
FLZapped's Avatar
FLZapped
I do this, even with my big hands, I can get to them OK.
Old Apr 19, 2014 | 06:20 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
Yep...this is how I did mine:
Old Apr 19, 2014 | 08:33 PM
chasboy's Avatar
chasboy
Oldtimer
and the Junkman's method works too.
Old Apr 19, 2014 | 08:40 PM
Clancy209's Avatar
Clancy209
I did mine using the junk-mans method, put plenty of WD-40 on your forearms.
Old Apr 19, 2014 | 08:46 PM
envyz06's Avatar
envyz06
for me it was going under, was a pain in the *** to get my grille lined back up for the z06.
Old Apr 19, 2014 | 08:47 PM
Loby 1's Avatar
Loby 1
Why?
Only your hand goes in the port.
Old Apr 19, 2014 | 09:26 PM
Clancy209's Avatar
Clancy209
I did turn signal bulbs also
To C5 DRL Replacement
