Well the front driver rotor cracked the other day and it's time to buy a good set of rotors. I will be doing auto X and maybe a track day. I would like to get a pair for the fronts for under $500. What should I get. Thanks
If anyone has a pair they would like to sell. Let me know.
As you can see it cracked at the drilled hole. I think i am going to go with a slotted rotor only. No more holes.
And these had maybe 5k miles on them.
Notice that the C7 Corvette has slotted-only rotors. The program manager explained that many of the drilled C6 rotors (from the factory) did crack during hard use.
The high-end rotors with holes will have the holes cast in place as part of the casting operation. The holes only get a taper finish before the casting is machined.
Holes drilled in a casting will cause some weakening of the material around the drilled area. Extreme heat from braking such as during HPDE's or track days will cause cracking around those holes. Autocross is not as much as a problem but that depends on the speeds encountered at A-X events.
I have a C5 front brake conversion on my '87 and I just use regular stock replacement rotors for autocross and track use. Raybestos "Advanced Technology" rotors work very well for the use the car gets. They typically run $60 each. Part numbers: Right- 56700 and Left-56701
Regardless of the rotor type, it's a good idea to use some sort of ducting so the brakes can get as much cooling air as possible.
Who is the manufacturer? This is a defect vs. normal wear and tear. I know my Eradispeeds have a lifetime warranty, however I've never tracked my C5 either.
They are the ones that brake motive sell. I know exactly when it happened. I was on my way to work just got It out for spring and was doing some spirited driving and got on the brakes hard. I then parked it for 4 hrs. After I came out to drive to lunch I noticed a problem with the brakes.
I have seen other threads of people with the same brakes having the same problem.
Most, if not all rotor manufacturers are reluctant to give up data that they've spent lots of time and money accumulating. You need to talk to the folks at AP Racing and the team leaders of factory racing teams, like the C6R team. Ask them why they consistently choose slotted rotors over blank rotors. In fact, talk to the guys who selected slotted rotors for the ACR Viper and C7.
the c5 and c6r are on carbon brakes, not iron
the less the metal is disturbed the more reliable it is. this is why blanks, made from high carbon iron tend to be the strongest of the "normal people" rotors
the slots are cosmetic thing and some very high temp pads may see a minor improvement due to gassing
