C5 CAGS Defeat Install
Old Apr 23, 2014 | 10:36 AM
ChuckWalters's Avatar
ChuckWalters
Default C5 CAGS Defeat Install
I just ordered the CAGS Defeat from Southern Car Parts and read the instructions posted below the parts description on their site. Looks like it couldn't be any easier. My question is about jacking it up. Can I just lift one side of the car to get to the plug or do I have to lift the whole front (or rear)? Any install pictures around?
Old Apr 23, 2014 | 10:59 AM
mr_get_iton's Avatar
mr_get_iton
I installed mine on a lift, but I'm sure you could crawl under the left rear of the car to add it.
Old Apr 23, 2014 | 11:21 AM
john8642's Avatar
john8642
I don't see how you could safely jack up one side of the car. It would be sitting on the jack stand at an angle. Using ramps or jacking up one end would be much safer in my opinion.
Old Apr 23, 2014 | 02:02 PM
ChuckWalters
Originally Posted by 8VETTE7
Perhaps too late now but Compliance Auto Parts sells a CAGS defeat that does not require getting under the car. Installs in the passenger foot well AND also keeps the 1 to 4 light on the dash from coming on. That light is still illuminated with the resistor setup you ordered
Cannot find any web reference to Compliance Auto Parts????
Old Apr 23, 2014 | 02:30 PM
ChuckWalters
http://www.complianceparts.com/
Cags is on the left column at the end for C5
Thank you! I was using Compliance Auto Parts.......
Old Apr 23, 2014 | 02:35 PM
MyNameIsJared's Avatar
MyNameIsJared
I installed the skip shift from Compliance last weekend and it was extremely easy to do. It actually installs near the battery, I think you might have it mixed up with the LMC5 they offer that installs in the foot well.
I'll also note that the customer service was outstanding. I had an issue with my column lock when installing the LMC5. I called the support number and Richard was extremely knowledgeable about what was the issue and we solved it very quickly.
Definitely glad to have both those installed on the Vette. Should have done it a couple years ago, would have saved myself some headaches.
Old Apr 23, 2014 | 02:54 PM
540i 6spd's Avatar
540i 6spd
Skip shift removal is one of the best mods!!!
Old Apr 23, 2014 | 04:37 PM
GoldenFlame's Avatar
GoldenFlame
I had mine removed via Mail Order Tune.. Hated that crap
Old Apr 23, 2014 | 05:43 PM
ChuckWalters
Ordered the CAGS Shift Eliminator from Southern Car Parts. I am not concerned if the light comes on for a second. Someday I will have it programmed out. I read somewhere that someone backed there car up onto a pair of Rhino Ramps. I am curious if the front end will hit if I do this. I have a jack and jack stands, but the ramp idea would be quicker. Any experiences from members on backing your C5 up onto ramps? The car is stock height from the ground and stock wheels and tires.
Old Apr 23, 2014 | 05:46 PM
You can just lift up the rear driver's side and install the CAGS eliminator. Very easy to do, just be sure to put a jack stand under the car also for added safety.
Old Apr 23, 2014 | 05:49 PM
Narco944's Avatar
Narco944
Jack up the center rear of the car and slide a jack stand on each side. That's all you need. Start to finish less than 10 minutes
Old Apr 23, 2014 | 05:54 PM
ChuckWalters
Thank you everyone and thank you Jack and Roger!
Old Apr 23, 2014 | 06:27 PM
andrec10's Avatar
andrec10
You can also have it tuned out. Dont miss mine at all!
Old Apr 23, 2014 | 08:31 PM
Tblaum's Avatar
Tblaum
That's how I did mine, no problem with the front hitting, at least on mine.
Old May 9, 2014 | 03:01 PM
ChuckWalters
I just finished installing the CAGS Shift Eliminator a few moments ago. Piece of cake and took all of two minutes to do (when you locate the correct place to install it). I had to call Dave at Southern Car Parts and ask a dumb question about the correct location, but he was GREAT! Truly a wonderful company to deal with......test drive with it tomorrow....cannot wait! Thanks again to all those who chimed in on the thread and a special thank you to Dave!
Old May 9, 2014 | 06:23 PM
hougland's Avatar
hougland
LOL, Thanks for clearing that up!!! I've been reading some of these CAG Q&A's and was wondering " WHY IN THE HELL ARE THEY LIFTING THE CAR". I too have the compliance CAG defeat, it was a breeze to install.
To C5 CAGS Defeat Install
