Looking for seat replacement/conversion options
Old Apr 23, 2014 | 05:24 PM
troyguitar's Avatar
troyguitar
Default Looking for seat replacement/conversion options
I'm looking to upgrade/replace my Z06 seats with something that does the following:
Maintains factory or factory-like adjustment ability including fold-forward to access behind seats. Does not necessarily need power/memory options but that would be a plus.
Have heater option or easily removable covers so I can add aftermarket heaters.
Have pass-through holes to allow for later harness addition.
Have greatly improved lateral support - particularly for a very small driver. I'm 5'10" but 150 lbs with 36" chest and 30" waist.
I basically want a great street seat for daily use that I can also put a harness on and use on the track. My original intention was to do buy the Marrad upgraded seat-backs plus add heaters, but sometime in the past couple of weeks it seems they have stopped offering that service. Now I'm at a loss. Can any other seat offer the same features?
Old Apr 23, 2014 | 05:40 PM
racebum's Avatar
racebum
black leather recaros from an evo 8 or 9 are what you want
really your only choice. the aftermarket seats like corbeau are junk. thin mild steel frames that aren't even legal if an FIA or OEM seat is mandated. they will kill you in a wreck and their materials make china look like quality
i'm sure i'll catch hell for saying so but put a corbeau and a recaro next to each other
it's like a ferrari and a ferrari kit car when you look at construction
Old Apr 23, 2014 | 05:42 PM
66dts-v's Avatar
66dts-v
Corbeau A4 is about as good a seat as you will find with those features. They aren't crazy expensive compared to others.
I've been looking and sitting in seats since I bought my car. I will either end up with fixed seats, or something modified stock like a Mitsubishi Evo Recaro seat or Porsche seat.
Unless you add aftermarket heaters, the Evo seats aren't heated stock from what I've gathered.
<edit> I'm not a fan of the A4, but it isn't as bad as the knock off seats.
Old Apr 23, 2014 | 06:24 PM
troyguitar's Avatar
troyguitar
I had looked at the Recaro Sportster CS for my old Audi but didn't think it would be narrow enough to fit in a C5. If they fit that would be nice.
It's really too bad it's nearly impossible to sit in any of these things without buying them.
Old Apr 23, 2014 | 06:33 PM
marrad's Avatar
0marrad
Former Vendor
Yes, I apologize for that. We had a customer report a problem that no other customer had ever mentioned. The frame of our seat conversion was square in the back and the factory seats have a bevel on the rear edges. The bevel is needed if the seat track is traveled all the way back and the seat hits the wall. The customer reported if the seat was all the way back, our back would bind on the tunnel and force the seat back too vertical for him to use. We need to redesign the frame to fix that before selling them again.
If you send me an email
I can contact you when something develops.
Old Apr 23, 2014 | 06:35 PM
66dts-v's Avatar
66dts-v
The Evo seat is a slightly cheaper OE version of the Recaro Sport.
Old Apr 23, 2014 | 11:04 PM
troyguitar's Avatar
troyguitar
Reading further about the Corbeau A4 has me thinking about them as a possible option, but it looks like they lose the ability to fold forward to reach anything behind the seat. Other than that a pair of A4's in black leather can be bought with sub-belt slots and heaters pre-installed, bases shaved down an inch, and brackets with double-locking sliders all under $2k shipped. That really seems hard to beat since the seats are sized for small people like me... it will probably come down to the A4 or the Marrad conversion.
Old Apr 24, 2014 | 01:00 AM
kodell's Avatar
kodell
I have also been interested in replacement seats for my '00 convertible (still have the stock seats).
was told that corbeau A4 was the best choice if i did not want to spend the extra money on Recaros.
but i was also told by someone else that Recaro seats do not fit in a C5 without significant modifications made to the doors and transmission tunnel.
can anyone verify this?
if they do fit, do only some models fit without any modification? if so, which ones?
Old Apr 24, 2014 | 01:36 AM
racebum's Avatar
racebum
look at them in person first
the craftsmanship, material quality and strength of frame is just not up to par
Old Apr 24, 2014 | 09:51 AM
troyguitar's Avatar
troyguitar
The joys of living in the middle of nowhere, I can't try anything before buying ever.
Old Apr 24, 2014 | 11:05 AM
66dts-v's Avatar
66dts-v
It depends on the model of seat, that goes for any seat manufacturer. I know the Recaro Sport should fit, you can get a Sport Topline with full power and heat options, I think.
The C5/6 chassis is narrow, but there are some seats skinny enough to fit. My other issue is I'm not a small guy. 6'4" with a 36" waist. So the seat has to be skinny enough to fit in the car, but wide enough for me to fit in it.
Old Apr 24, 2014 | 11:26 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
subbed...I may need seats.
Old Apr 24, 2014 | 11:34 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I've got pair of Evo 8s going in next week. With manual sliders, they weigh about the same as the electric stock seats, but of much better, heavier duty construction. I had to fabricate my own brackets, modify the seat belt trim panel and install C6 belts, but it'll be worth it. Pictures will be forthcoming once they're in place.
Old Apr 24, 2014 | 07:58 PM
kodell's Avatar
kodell
Default recaro seats
Today I spoke to Dave at the customer service section of the Recaro office in Auburn Hills, MI.
He informed me that because of the C5's narrow seat space, the only seats which will fit in a C5 (without modification to the car's interior) is the Profi and the Pole Position.
These are fixed seats and will require some customization of the C5's stock mounts or the mounts that they can provide. Their seats will not directly fit on to the stock mounts.
Old Apr 24, 2014 | 08:01 PM
racebum's Avatar
racebum
evo 8 seats fit, pics of the install are here on the forum
read this thread http://forums.corvetteforum.com/c5-g...or-the-c5.html
Old Apr 25, 2014 | 02:36 PM
66dts-v's Avatar
66dts-v
Yes, I have been told and have seen both Evo 8 and 9, but it seems the 10 might be too big. It's funny to me because my buddy has an Evo 8 and the main thing he doesn't like about the car is the seats.
He sat in mine and quit bitching. They are a nice OE seat.
Old May 1, 2014 | 09:31 AM
Lucario6613's Avatar
Lucario6613
To the guys that did this what did you do about the seat belt buckle? Im using Wedge engineering brackets. The buckle on the Evo seat is about 2.5" shorter than our stock Vette seats due to mounting point. The factory C5 belts wont fit into the Evo buckle. Did you guys cut down the buckle to length or swap the C5 buckle to the Evo bracket?
Old May 1, 2014 | 10:53 AM
c5vetteguy's Avatar
c5vetteguy
The Evo 8 belt receptacles are attached to the seats. I retained these, but the tang on the C5 & C6 belt buckles is a tad wider. I just Dremeled down the tang width (C6 belts in my case) until it fit in the receptacle. The length is fine. It doesn't take much (off) to make them work properly.
Old May 1, 2014 | 11:03 AM
Lucario6613
You're a life saver. I was going to try dismantling the 2 buckles and install the c5 buckle on the Evo bracket.
To Looking for seat replacement/conversion options
