Power Antenna
Old Apr 24, 2014 | 01:46 PM
chough262's Avatar
chough262
Default Power Antenna
1999 convertible. My antenna is stuck in the "up" position. I can hear the motor humming when i turn on the key and turn it back off. Would this sound like i can replace the nylon cable? Or should i just get a new antenna? thanks
Old Apr 24, 2014 | 02:16 PM
Corvette_Ed's Avatar
Corvette_Ed
If you can hear the motor running then you most likely have a broken gear, which means that you will need to replace the antenna.
Old Apr 24, 2014 | 03:07 PM
Vettmann17's Avatar
Vettmann17
Here ya go, easy fix. See post #:15
http://forums.corvetteforum.com/c5-t...post1562023108
To Power Antenna
