[Z06] Valve spring failure
Old Apr 25, 2014 | 10:16 AM
Kins13y's Avatar
Kins13y
Default Valve spring failure
Found out my Z06 suffered the dreaded valve spring failure. Turns out I got lucky and the valve didn't drop. The shop I have it at said I'm about the luckiest person they have seen.
[IMG][/IMG]
Old Apr 25, 2014 | 10:47 AM
LuckySon's Avatar
LuckySon
Very lucky it sounds like!
Hope to have mine replaced soon as a preventative measure. Scary.
Old Apr 25, 2014 | 11:08 AM
Kins13y's Avatar
Kins13y
After mine failing I would have to say that it is a must haha.
Old Apr 25, 2014 | 11:31 AM
MY03C5Z's Avatar
MY03C5Z
Looks like you were very lucky. Original springs I assume? What year?
Old Apr 25, 2014 | 12:31 PM
Kins13y's Avatar
Kins13y
Stock springs as far as I know. I have owned since last September, its an 02' with 82,000 miles.
Old Apr 25, 2014 | 01:50 PM
MY03C5Z's Avatar
MY03C5Z
Many of the stock springs were yellow, 02's were at the biggest risk of failure along with early model year 03's, which mine was. Replaced mine shortly after buying it two years ago.
Old Apr 25, 2014 | 02:22 PM
93civEJ1's Avatar
93civEJ1
My 01 stock springs are blue.
Old Apr 25, 2014 | 02:32 PM
pit-man's Avatar
pit-man
You are lucky. My failure cost $11k...however that replacement has been great. A 383 stroker and new clutch.
Went from mid 11's to mid 10's
Old Apr 25, 2014 | 03:06 PM
MY03C5Z's Avatar
MY03C5Z
Did you buy the car in the last few years? If so they probably have been replaced. The GM ls2/3 replacement springs are blue. Thats what color mine were I ordered from GM parts warehouse.
Old Apr 25, 2014 | 08:08 PM
skyavonee's Avatar
skyavonee
Last 5 digits of VIN?
Old Apr 25, 2014 | 08:16 PM
skyavonee's Avatar
skyavonee
I don't have you on the master list. If your engine was stock when the valve spring failed, can you also post or PM me the last 5 digits of your VIN?
Old Apr 25, 2014 | 08:17 PM
apollo240's Avatar
apollo240
How are your driving habits? Ive heard this can be a factor?
Old Apr 25, 2014 | 08:54 PM
Z06ness03's Avatar
Z06ness03
Good time to upgrade to beehives with titanium retainers and chromoly push rods.
Old Apr 25, 2014 | 09:11 PM
racebum's Avatar
racebum
stock 01 springs were actually blue from the factory
not the same spring as the new ls2/ls6 springs we use to replace
Old Apr 27, 2014 | 04:13 PM
Kins13y's Avatar
Kins13y
I don't have the VIN available right now. Turns out I must have been lucky. I have my fun with the car but I don't tend to race it. It's now getting new valve springs, a tune, and longtubes/xpipe from Texas Speed.
Old Apr 28, 2014 | 07:19 AM
RED02Z's Avatar
RED02Z
What kind of spring do you replace with??
Old Apr 28, 2014 | 08:53 AM
rjwz28's Avatar
rjwz28
I had a PRC dual valvespring break on my Z06 when it had the MS3... fortunately the other coil held things together until we figured it out. It was floating valves on the dyno at only 5200rpm or so, and still made 360rwhp in spite of the problem.
To Valve spring failure
Old Apr 28, 2014 | 09:37 AM
Kins13y's Avatar
Kins13y
I don't know the exact valve springs as I ordered them through a local shop but its PRC stuff. I plan to get it figured out but it will probably be a little while this particular shop is very busy.
Old Apr 28, 2014 | 09:41 AM
RED02Z's Avatar
RED02Z
If you would, when you find out what they are... Post them on here please. Thank you Sir.
Old Apr 28, 2014 | 12:23 PM
RED02Z's Avatar
RED02Z
Thanks bumble
