Tire recommendation
The extra weight is only a few pounds. Not a big deal.
I've had a couple of flats, over the years, and simply changing a tire with an OE jack and lug wrench, on the side of the road, can be a MAJOR safety issue as well as a PITA. I cannot imagine trying to plug a tire. I'll stick with the RFs.....
Corvettes are touring cars, too.
You drive any distance on a deflated runflat you most likely will have to replace the tire. That's a good thing in your opinion?
I keep a slime repair kit in the trunk.
6mo old is the average for a high volume dealer like tire rack or discount
my local discount is really good about checking dates when i buy and making sure they are under 1yr old, always buy local when you can guys, support your community.
It really amazes me, how so simplistic some of you guys are. For example, the last time I got a flat tire on the road, I happened to be in my wife's car, which at the time, was a '93 Caprice LTZ. The car in front of me kicked up a piece of metal, or something, and it ricocheted off his tire, into the concrete guard rail, and back into my path.
I saw it coming, twitched the steering wheel, missed it with the front tire, but got it with the rear. This piece of s**t cut a 4" long gash in the sidewall of the tire, completely blowing out the tire.
OK, it wasn't my Corvette, but nonetheless, that kind of crap can happen in daily driving, and a Corvette doesn't have a spare tire. (Thankfully, the Caprice did) Are you going to fix a destroyed sidewall with a can of "fix a flat"??? Oh, yeah, I was on my way to work, too, and needed to be there "on time", so calling the AAA in the morning commute hours, and waiting until they manage to show up isn't all that practical either.
NO, I don't track the car, so I don't need that last 1-2% of the car's potential performance. And secondly, if you blow out a tire at the track, you're at most 2-3 miles to the pits, where you can slap on a new tire. Out cruising, you could be MILES from any kind of help.
I am going to replace my tires and after hearing all the pros and cons I am going with the non runflats. The different opinions helped me make the decision. If you only want to hear opinions just like your own, you might as well be done here.
I switched to Bridgestone RE760s and the ride quality, wet traction, and noise level have all greatly improved along with better performance.
Im gonna stick with the 760s I think they are a good DD performance tire.
