Cruise Control Disengaging
Old Apr 28, 2014 | 11:33 AM
Dmiles2004's Avatar
Dmiles2004
Default Cruise Control Disengaging
I was on my way to work and the cruise control on my 2004 coupe disengaged twice on its own. Any thoughts as to why and what to check? I pulled the codes and there were none.
Old Apr 28, 2014 | 11:42 AM
Lee DeRaud's Avatar
Lee DeRaud
Manual? It will disengage when the clutch is depressed, but I don't know how sensitive it is. It may be triggering if you're resting your foot on the pedal in traffic, or even just nudging it from the side with your foot. EDIT: it's a normally-closed switch on the clutch pedal bracket: check the connector to it.
It will also disengage if you speed up past the set point (e.g. to pass) for more than 60 seconds.
Old Apr 28, 2014 | 11:52 AM
Dmiles2004's Avatar
Dmiles2004
Sorry, I forgot to mention it's an automatic. I wasn't in traffic. Just cruising about 70 mph and it just shut off. I hit resume and it picked right back up only to disengage about 4 miles later. Resumed once more and it was fine for the remaining 12 miles. ?????
Old Apr 28, 2014 | 11:55 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Both the clutch pedal (if it's a manual) and the brake pedal have switches on them that interupt the cruise circuit as soon as the pedal is depressed. I would check the adjustment of those switches and their electrical connectors first.
Old Apr 28, 2014 | 12:00 PM
jrose7004's Avatar
jrose7004
When mine started doing that it was related to the steering sensor going bad. Once that was replaced it stopped.
Old Apr 28, 2014 | 12:55 PM
Phanni's Avatar
Phanni
That's the usual cause.
Old Apr 28, 2014 | 01:46 PM
coia96vette's Avatar
coia96vette
That is what happened to my 04 A4. It took awhile to set the codes. Then it came up with C1287/C1288 that was the SWPS going out. Replaced it and all is good now.
Old Apr 28, 2014 | 01:59 PM
jrp1588's Avatar
jrp1588
Crap, mine has been doing this off and on for a while now.
Old Apr 28, 2014 | 02:10 PM
Lee DeRaud's Avatar
Lee DeRaud
I wouldn't start replacing parts until some codes trigger. According to the FSM, cruise control will disengage if the ABS/TC (and presumably AH as well) activates for more than 2 seconds. I can believe the SWPS can cause that, but there will be codes and symptoms unrelated to the cruise control to point you that way.
Old Apr 28, 2014 | 02:13 PM
jrose7004's Avatar
jrose7004
Also it is normally accompanied by "Service Traction Control" message on the DIC.
Old Apr 28, 2014 | 02:36 PM
Lee DeRaud's Avatar
Lee DeRaud
I think that qualifies as a "symptom".
Old Apr 28, 2014 | 03:01 PM
jrp1588's Avatar
jrp1588
Mine usually does it when I hit a bump in the road. I'm positive I haven't touched a pedal, and no traction control lights come on. I think I do have a loose connection somewhere in the speed sensors on the hubs. Occasionally when tcs activated from lose gravel i get a service traction control warning until I restart the car. Could that have anything to do with it?
Old Apr 28, 2014 | 03:10 PM
SilverC54me's Avatar
SilverC54me
The SWPS codes clear when the ignition is tuned off. Pull the codes after a cruise control disengagement after coming to a stop while the engine is still running.
90% chance it is the SWPS. It could be any of the wheel sensors or other ABS TSC sensors also. The most common one is the SWPS.
Takes about 2.5 hours to do. I would recommend pulling the steering column out completely when changing one.
First thing is to verify the codes generated.
Gary
Old Apr 28, 2014 | 03:15 PM
DeeGee's Avatar
DeeGee
I agree. Pull the codes and post them up. The trip is a symptom. You'll have an active handling problem that's causing it. In my case its a C1287/1288
Old Apr 28, 2014 | 03:29 PM
Biggun6969's Avatar
Biggun6969
Default Same here
Mine only does it when I use the right blinker; usually when changing lanes. And it only does it sometimes. I figured it was the steering sensor on it's way out.
Old Apr 28, 2014 | 03:45 PM
wcsinx's Avatar
wcsinx
Same here, mine would sporadically disengage cruise for years before the SWPS finally got bad enough to set a code. Swapped a new one in, and it hasn't done that since.
One thing you can try that narrows it down a little is to turn off AH/TC. If your cruise starts behaving normally with that off, then it's likely the SWPS and not the clutch/brake switches.
No they do not. They simple become history 'H' codes.
Again, my car behaved that way for a very long time before setting codes. The SWPS can send bad data that will cause the cruise to disengage, but it may or may not be far enough out of tolerance to set a trouble code.
Old Apr 28, 2014 | 04:33 PM
Phanni's Avatar
Phanni
Old Apr 28, 2014 | 09:37 PM
david1st's Avatar
david1st
My 4A just did that a day ago..... Cruse disengaged and then active handling popped up on my display. .????
To Cruise Control Disengaging
