suspension lean
Old Apr 29, 2014 | 03:29 PM
hougland's Avatar
hougland
Default suspension lean
I just started Auto X and realize that I am getting way to much lean on the corners. I run a 2000 vert with adjustable suspension which I run on the hardest setting. Was looking at the pictures of her in the turns and was surprised at how much lean there was.
This is a daily driver and I don't intend to make a race car out of her. But I would like to do better at the Auto X track.
Would I see a big improvement by switching to a different set of sway bars? What are your thoughts?
I would like to stay in the Stock class.
Old Apr 29, 2014 | 03:33 PM
xpunter83's Avatar
xpunter83
upgrade to some c6 Z06 shocks and sways, makes a big difference
Old Apr 29, 2014 | 03:34 PM
andrec10's Avatar
andrec10
Old Apr 29, 2014 | 03:40 PM
zagger's Avatar
zagger
Just switching to C6Z51 sway bars and end links will make a very noticeable difference and won't sacrifice smooth ride for DD.
Old Apr 29, 2014 | 04:45 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I did the bars but not the shocks yet......
Liked the improvement immediately.
Inexpensive and easy install.
Old Apr 29, 2014 | 06:14 PM
vette6ssp's Avatar
vette6ssp
3rd Gear
I believe per SCCA rules only one sway bar may be replaced and still be in a stock class. Once you replace both sway bars you would be bumped into SSP i believe. The stock size is a 23mm any size up from that would be an improvement but will vary depending on courses and driving style so you need to find one that fits you. I have a 1999 corvette with C6 Z51 sways and shocks and it made a huge difference regarding body roll. If you were to change one change the front. With a stiffer bar you might push through corners a bit more so you might have to adjust camber (more negative). Also adjusting caster would help as well (more positive to achieve more dynamic camber). If you need help with the alignment you can contact me and i can send you a link from David Farmer...a little off topic but might help you.
Hope this helps
Old Apr 29, 2014 | 06:56 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Hope this helps
Yeah, I had to bump up from stock.
To suspension lean
