So......installed a Vararam and what a pain. I read about them and knew going into it that it would be hard, but it for sure took more time then i thought. Anyways, got it installed, drove my car about 100 miles yesterday and it ran fine. No codes or anything. One thing I am noticing is my oil pressure is running a little higher then it used too. Not spiking, but higher. Is that normal, or is that ok? Thanks in advance!
when I get mine im debating on doing it myself or just letting corvettes of Houston do it. they only charge like 75 bucks, and according to the nightmares ive heard on installing it that sounds like a good deal hahah.
Here on the east coast we have had torrential rain storms the last few days. And I have read over and over here countless times here of Vararam intake owners, not thinking and wading through high water and Wam, your engine is hydolocked. broken pistons, cracked rods and a shot engines. So please, just don't become thoughtless and remember the unit is down there in front of your car. C5's sit low in the front as it is, don't kiss your engine away by simply cruising into 6" of deep water.
If 75 bucks is all they charge i would highly recommend it as long as its a shop u can trust. They are a headache to put it. I do most my own work on my car and i am glad its done, but i would be hesitant to ever do another one. Good luck!!
Thanks for the heads up!! I heard u guys are getting slamed over there. We get allot of rain here in WA but my car is a fair weather car so should be ok.
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Define "countless" please. I've been posting here for a few years and countless to me is 1.
What is countless is the number of times people claim vr's hydrolock engines in the rain
I haven't even seen one post where someone hydrolocked their engine due to the vararam... now just about every post is about the crappy build quality and poor fitment but they do work, to me that is countless... but if you drive through high enough water to submerge half of your front bumper and lock up your engine you should be blaming yourself and not a vararam
Ok, I'm not badmouthing Vararam cold air inducting, but the intake is like 8" off the road surface and since I've been here for a longtime, I can remember a lot of "Sorry the day after" stories of a minute of not thinking and @60MPH they hit a low spot in the road that had a pond of water sitting in it. Does it mean the driver is at fault? Well I don't think so as we all have had those moments where the area just ahead of your headlight is sitting water. And that water can cause some big problems. I'm just saying with a intake that sits up inside the open spot forward of the radiator, it's still cold air intake, it just sits higher up.
St. Jude Donor '13
I haven't been here near as long as you and I recall only 1 case. Right around 2 years ago. He got a new engine from the insurance claim. There was something about Removing the VR from the car before the adjuster saw it.
Other than that one case all the rest of the complaints were my friends brothers second cousins mothers uncle knew a guy type stories.
This is not a new product so anyone purchasing it should be aware of the risk and take appropriate precautions when driving. It is the crappiest fit but the best functioning CAI out there. I had two and even tho I slammed it for fit and finish I can also attest it produces best gains of all others.
As to OP question, your engine may be ruining little lean for a while after the install specially at speed where the Vararam does it's work. Normally the computer will adjust fairly quickly but in case of Vararam the air/fuel changes more at speed and might take longer for computer to find a happy medium. Leaner = hotter engine so keep an eye on it for a while longer, should get back to normal soon.
Thanks!! I agree, crappy fit but from what i can tell it seems to be the best. I am aware of the hydro lock issues but i hardly drive it in bad weather and if I do I will be cautious. Thanks again!
I have been on this board for just over 8 years and I have heard of only 1 incident with a vararam hydro locking a car. I believe it is an urban myth that there is any significant number of incidents caused by the VR.
I also have a VR and thanks for the reminder! Up here in the desert, it rarely rains but when it does, it floods. I try to keep her garaged on those three days-a-year. On the fit issue? Yep I also agree. It has been a challenge to make it fit correctly.
any intake that you install on a vette or any car that sets low such as a vette that your drive careless you will have issues with ...use your head!!!!
I have this same issue on the oil PSI. still under 500 miles with the V intake. Have not noticed hotter engine temps (actually the opposite) but my Oil PSI was usually at 40 and now runs about 45-50 when on throttle. At idle it stays at 38-40 per manual for A4. Running fine so far.
If the car is sitting at stock ride height the air intake opening bottom is at 10 inches off the surface. And Vararam is a forced cold air intake. That doesn't mean that other cold air intakes are not good products and many owners of those systems are quite satisfied with them.
