Map lights only work when i squeeze mirror
Old May 1, 2014 | 04:35 PM
twettybyrd's Avatar
twettybyrd
Default Map lights only work when i squeeze mirror
hi folks mine's a 2001 coupe
i removed rv mirror to replace bulbs but they work fine when i squeeze
fairly firm on each side of on/off buttons not touching buttons i don't know
what to do next?
any help will earn you good karma. thx
Old May 1, 2014 | 04:39 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Bad connection some where in the mirror. Could be the lights or could be the switch. First guess is the switch.
Old May 1, 2014 | 10:39 PM
chuckeb84's Avatar
chuckeb84
what to do next?
Just make sure you put it back together securely
Old Jun 16, 2014 | 12:07 AM
twettybyrd's Avatar
twettybyrd
Bump
To Map lights only work when i squeeze mirror
