Just noticed yesterday that the drivers side running light bulb has gone out. When I turn on the left turn signal now it flashes a lot faster than it should. That's how I figured out that it had burned out. How hard will this bulb be to replace? Any way to get to it without lifting the front of the car? Look forward to hearing back from the forum, I've never been let down. You guys/gals rock!
I used the method shown in the youtube video. The only small issue was the direction the clip turned to remove it is opposite for one side or the other, don't remember which. Took less than five minutes to change without removing anything.
I used my other hand palm down, which was easier for me.
I was having trouble with my passenger side light. It wasn't burned out, just not making good contact. I cleaned the contacts, but eventually I had to gently pry the contacts out some so they created more pressure on the bulb. Haven't had any trouble since.
if you have skinny arms you could pop up the headlight, remove the plastic shroud and reach down and remove the bulb from the top.
'Yo Chris, your way worked like a charm! I just want to say thanks to all of you that replied to my thread. As usual it worked out great. I tried the Youtube way first but had trouble getting the housing out. Taking off the headlamp plastic cover (2 screws) worked great. It gave me much more room to work with and a better angle. If you try either way, make sure you press the clamp on the housing before you try to twist and pull out the housing. I don't think that little safety tip was mentioned earlier.
Glad you got it to work the way you used. When I replaced my DRLs and side running lights, I went ahead and removed the lower access panel under the fascia but then again, I was changing out the light housings at the same time.
Again, many thanks to all.
I have the same task to perform. Just wondering, I'd like to raise the headlights without turning them on. I've seen posted a way to do this but I don't remember the procedure. Did you do this and if so what's the procedure?
I have changed the DRL bulbs in my C5 using the method demonstrated in the video a couple of times. Works well.
Slight thread hijack here but directly related. I have also changed the sockets. My replacement of the sockets was the second time as there were already a pair of "CHEAP" replacement sockets installed by a previous owner (I am number 4 on this car). If you have to change the sockets don't buy the ones with three tiny white wires. Buy the ones from NAPA that have the factory gauge, properly color coded wires and, if you have the ability, wire the existing harness and the replacement sockets with Delphi connectors so that if you ever have to change them again you won't have to shorten the harness in the car again. Don't be afraid to use a copious quantity of grease when seating the bulb in the socket. Keeps the moisture out that causes the damage to the socket in the first place.
Just changed the passenger side turn indicator bulb using the method in the video, i.e., popped the brake air duct out of the way, etc. It's not the hand size so much as the circumference of your wrist. Couple of ideas that worked for me: 1) lotion-up your hand and wrist; if you're near the fit limit it sure helps. I also used a little plastic & rubber assembly lubricant ("P80") on the bulb receptacle to help it go back in much easier. FYI, the bulbs face "up", and the connector wires are on the in-board side. The receptacle rotates such that the wires pivot toward the front of the car. On the passenger side, that's clockwise as viewed from the top, looking down.
