[Z06] Need some help
Old May 6, 2014 | 02:18 PM
1BACORVETTE's Avatar
1BACORVETTE
Default Need some help
My 2003 Z06 information center started flashing "Service Traction System and ABS". It came on before occasionally and I shut off and restarted, but this time it is staying on. Any ideas on the problem?
Please don't tell me my computer board is bad.
Dave
Old May 6, 2014 | 05:12 PM
rjwz28's Avatar
rjwz28
Dave
Search for threads regarding wheels speed sensors
Also, have you recently switched or rotated tires?
Old May 6, 2014 | 06:41 PM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
Check your codes and post them up - with that info someone that knows a lot more than I do will be able to give you a more detailed answer.
Old May 6, 2014 | 06:44 PM
rjwz28's Avatar
rjwz28
Old May 6, 2014 | 07:09 PM
1BACORVETTE
No I have not rotated tires. I have not even driven the car that much. It only has 30k miles on it. I have driven it maybe 200 miles in the past 3 mo. Been out of town. Codes are 28-TCS
C1214, C1221, C1222, AND C1248 which is not even listed on the code list. Go figure.
Old May 6, 2014 | 07:53 PM
usgecko's Avatar
usgecko
Search forum for c1248 - seems it's a genuine code - hopefully someone that knows their stuff can help.
Old May 7, 2014 | 12:53 PM
1BACORVETTE
Nothing found on C-1248!
Old May 7, 2014 | 05:53 PM
usgecko's Avatar
usgecko
Take out the "-" - just search on c1248.
Also sometimes google will give you better search results - even for stuff on this forum.
Using c1248 in the forum search I came up with a load of stuff.
Here's a post with a pdf listing codes including c1248:
http://forums.corvetteforum.com/c5-t...odes-dtcs.html
Here's some other posts with the same search:
http://forums.corvetteforum.com/c5-t...1248-code.html
http://forums.corvetteforum.com/c5-t...nsors-bad.html
http://forums.corvetteforum.com/c5-t...-no-codes.html
I would suggest you make a new post in the tech section with the codes you are showing in the title - will probably get a better response.
Good luck!
To Need some help
