Battery bolt
Old May 10, 2014 | 11:15 AM
bobjim3's Avatar
bobjim3
Default Battery bolt
Went to get my C5 out of winter storage and the ground cable bolt that goes into the side mount battery is stripped. Any easy solution?
Old May 10, 2014 | 11:19 AM
rob-cyn's Avatar
rob-cyn
Parts store will have something for you. I think when it happened to me I was able to get one that was slightly longer to grab.
Old May 10, 2014 | 11:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can do a Helicoil repair to it, not that hard to do to the female part on the battery!
Look at Youtube to properly do it!
Thanks,Matt
Old May 10, 2014 | 06:25 PM
C5RClone's Avatar
C5RClone
I had the same problem and found a replacement at Walmart.
Old May 10, 2014 | 10:07 PM
If it is the bolt that goes into the battery, you can get a replacement at an auto parts store. If it is on the battery where the bolt goes in, the that may require a helicoil.
Old May 11, 2014 | 12:36 AM
STL94LT1's Avatar
STL94LT1
Rarely if ever will the battery be stripped, it has stainless steel inserts. Buy another battery stud, push the old one out, push the new one in and tighten.
To Battery bolt
