coolant temps
Old May 20, 2014 | 07:59 PM
cobra3's Avatar
cobra3
Default coolant temps
OK I am sure that I am beating a dead horse here but going to ask the question anyway. What temp does your car run at when sitting at a light during the summer months. I live in Florida and the temps always seam to stay up around 200/205 area when at idle at a traffic light. I am for the most part stock , headers, CAI, cat back and a tune so I was thinking maybe a bigger rad, and a 180 thermostat. I guess you can change when your fans come on if I remember right , if so maybe I can get my tuner to change that for me.
Old May 20, 2014 | 08:14 PM
Clancy209's Avatar
Clancy209
my temp after driving is usually 219-225
Old May 20, 2014 | 08:51 PM
xdmikey's Avatar
xdmikey
Around 205 while sitting but below 200 when I get moving again, in houston.
Old May 20, 2014 | 09:19 PM
scarecrowkc5's Avatar
scarecrowkc5
If it starts to freak you out turn on the AC, that will turn on the fans and cool it down.
Old May 20, 2014 | 09:30 PM
frsr06's Avatar
frsr06
If we did not have a digital gauge there would be no issue. The temp redline at 260 should give an indication of trouble. If the arrow is anywhere straight up - no real problems.
Old May 20, 2014 | 10:17 PM
bobby777's Avatar
bobby777
10-4 - Nascar temps-240-260 at 190 mph-don't blow
Old May 20, 2014 | 10:36 PM
chuckeb84's Avatar
chuckeb84
My c4 went to 260 at the White Castle Drive through..
She cooled off while I ate my burgers and served me for years thereafter...
Fan switch was fried..easy fix..but that was my c4 from b4
Old May 21, 2014 | 07:43 AM
elkhunter2000's Avatar
elkhunter2000
6th Gear
I found mine running between 220-230 yesterday,no codes.runs fine hope this helps.i am gonna try to back flush radiator fins when i get the chance,heard these cars act like a road vacuum,alot of debris clogs radiator fins,i too am nervous about high temps
Old May 21, 2014 | 11:04 AM
Originally Posted by 8VETTE7
Absolutely nothing wrong with engine temps of 205 when sitting at a light. Perfectly normal.............. Many would love temps that low in traffic.............
The LS1 motor was designed to run at those temps.
To coolant temps
