[Z06] Rear Diff is Cracked after first time to the 1320.....
Old 05-21-2014, 06:58 PM
1999Firehawkls1
1999Firehawkls1's Avatar
Default Rear Diff is Cracked after first time to the 1320.....
Well this winter we upgraded to Driveline and thought it was enough................WRONG!!!
Ls2 w a Custom Grind Cam is under the Hood, 425whp/400Ft Lbs
We put a new McCloud RXT Twin Disc in (Which is hands down a Bad ****!!!!)
ECS Trans Brace
Pfat Rear End Mount
Hinson Super Cars Motor Mounts
AND a set of Nitto 555Rs.....
Went to Indy for the Vette shoot out just to run it twice to try for an 11 Flat and First Pass I think Cracked it and the 2nd time in the Burn Out Box the Diff Case cracked right where the Bolt Threads into the rear diff at thru the Pfat Rear End mount......crack continued down from there
Kick A$$ Clutch+ Nitto Drag Radials....= No GO!!!
Old 05-21-2014, 08:09 PM
nullpointer
nullpointer's Avatar
ECS Trans Brace
Pfat Rear End Mount
You cracked it in the burnout box? I've heard of cracking it while launching, but never in the burnout box. Did you get the tires a bit wet before dumping the clutch for the burnout?
Old 05-21-2014, 08:12 PM
1999Firehawkls1
Yea I got them in the water before the burn out.....duno it wheel hopped a bit in the first pass and that prob cracked it a bit and then in the Burn out Box finished it off is what im guessing....
Old 05-21-2014, 08:43 PM
nullpointer
Sucks, good luck with the rebuild. I've had to rip apart the diff twice, isn't fun.
Old 05-21-2014, 09:06 PM
1999Firehawkls1
Thanks! I just put the driveline back in it a month ago w the clutch and braces too..
Old 05-21-2014, 09:12 PM
sabastian458
sabastian458's Avatar
Can you post pictures of the failure point?
Old 05-21-2014, 11:11 PM
1999Firehawkls1
I can after this wk end when I get out to the shop
Old 05-22-2014, 07:34 PM
c5zee
c5zee's Avatar
I see a c6 diff in your future :o
Old 06-17-2014, 01:37 AM
1999Firehawkls1
Here is the nice view of the damage everyone has been wanting to see. Drag Radials Won this round....
Old 06-17-2014, 07:28 AM
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,693 Likes on 1,238 Posts
Bummer...
Unfortunately, racing = broken parts...and more HP = more broken parts.
It's just part of the game and the main reason I don't race. It IS a ton of fun, though...
Good luck with repairs!
Old 06-17-2014, 08:28 AM
quickc5zo6
quickc5zo6's Avatar
Damn how bad did you wheel hop?
What did you run on your firat pass?
Old 06-17-2014, 01:57 PM
zeevette
zeevette's Avatar
It only takes one hop, if it's stressful enough. I broke one hitting third gear hard. Good luck with the fix. I went with a built diff. by Rick@ RKT56.com.
Old 06-17-2014, 02:19 PM
MY03C5Z
MY03C5Z's Avatar
This is why I dont like to run mine at the strip, only ran it once so far. Ran my 97 LT1 z hundreds of times, loved racing that car. It was set up to handle the 1/4 though, HD torque arm, strong clutch, 12 bolt etc. That car could take a beating at the track and never broke anything.
Old 06-17-2014, 03:12 PM
PhiL02Z06
PhiL02Z06's Avatar
Scary! Wow! It's discouraging to see how weak the C5 driveline is,
Old 06-19-2014, 03:13 AM
1999Firehawkls1
Spun 1st, hopped a bit in 2nd, w a 2.6 60ft we ran a 12.2@120.9mph
Cars been 11.44@124mph (Ran by previous owner) w the old on it's way out Ls7 Clutch, just finished putting a McCloud RXT in this winter.
I was only gonna run the car that day for funny and be done w track driven it, I put on the ECS Trans brace and the Pfadt Rear mount at the time of the RXT install to prevent this from happening..... No more 1320 time for this car ever again! It was bought for a fun street car and will stay that way.
Old 06-19-2014, 03:18 AM
racebum
racebum's Avatar
dude, that's some good carnage
Old 06-19-2014, 03:24 AM
1999Firehawkls1
Think we can JB Weld it?!?!? Lol
To Rear Diff is Cracked after first time to the 1320.....
Old 06-19-2014, 01:56 PM
MY03C5Z
MY03C5Z's Avatar
Looked up that clutch, didnt know much about it. From the looks of it, solid unsprung hub designed to hold 1000hp Id say that was the main problem for your transaxle. That thing sounds like a beastly clutch!
Old 06-19-2014, 03:58 PM
racebum
racebum's Avatar
you ever drive one of those? they are ridiculous in engagement if they use a high friction material on the disc. transmit a lot of driveline shock
the torque tube couplers are what would worry me, if the shock is enough to break cases like that the couplers are getting raped dry
Old 06-19-2014, 05:39 PM
malibu78
malibu78's Avatar
I broke my case output shaft in trans and ate the ls9 clutch. Power shifted into 2nd and kabooy. Sounds like the car was previously owned just like mine. I am willing to bet there were a few banzai runs with severe wheel hop that weakened the drivetrain. If they wheel hop all the time it's not if but when it will break no matter how strong the parts
Quick Reply: [Z06] Rear Diff is Cracked after first time to the 1320.....
