Tire size question
May 22, 2014 | 11:30 AM
Tire size question
Looking at Continental DW's instead of DWS.
No 275/40/18 (26.7"). Next size is 285/40/18(27")
The front 245/45/17(25.7"). Will the larger rears mess with the AH system?
Thanks,
WJ
May 22, 2014 | 11:31 AM
No.
They will be fine. That's not that much bigger
May 22, 2014 | 11:53 AM
You can bump the fronts up to match better, but either way works fine. 255/45/17 and 285/40/18 would match well on stock size wheels. The DW comes in both sizes.
May 22, 2014 | 02:44 PM
Tire size
Thanks guys. I met quite a few corvette owners at Laguna Seca on the 5th. Good tire for summer only.
This will be my first time without run flats.
wj
I worked for Alcan 20 years here in Roseburg. Been to Williamsport many times.
Reason: adding info
May 23, 2014 | 12:50 PM
Quote:
Originally Posted by
troyguitar
Can you go a size wider on the rears? 295/35/18?
May 23, 2014 | 01:25 PM
I have Conti DW on my Z.
275 front (+1 from stock Z06)
295 rear (stock Z06 size)
May 23, 2014 | 05:27 PM
RedZMonte
can I do the same size on a base coupe?
May 23, 2014 | 06:21 PM
My base vert has conti DW 265-35-18 9.5 front and 295-35-18 10.5 rear without any problems.
