Torque tube bearings
Old May 23, 2014 | 07:21 PM
o1Z0sick's Avatar
o1Z0sick
Default Torque tube bearings
Is there a vendor that sells the good high speed bearings? There is a kit from rpm but it includes the couplers and i don't need those, just the bearings and slinger. Thanks.
Old May 23, 2014 | 07:34 PM
Black0ut's Avatar
Black0ut
I do know that if you have the bearing numbers a local bearing supply shop should stock SKF bearings in the right size. That's what I did upon cracking open my torque tube and finding every bearing was toasted- no time to order; just shopped local.
Front- skf 6007 2rsjem and Rear- skf 6008 2rsjem.
Old May 23, 2014 | 07:35 PM
o1Z0sick's Avatar
o1Z0sick
Awesome, thank you. Did you reuse the slinger?
Old May 23, 2014 | 07:39 PM
dr_whigham's Avatar
dr_whigham
Copied to my notes. Thanks for that.
Any difference between them and years? 2004 here...
Old May 23, 2014 | 07:46 PM
o1Z0sick's Avatar
o1Z0sick
I dont think so, the input and output are the same, just the prop shaft and couplers are different.
Old May 23, 2014 | 10:27 PM
o1Z0sick's Avatar
o1Z0sick
Here is what i found:
97-11 front propshaft use 6007
97-99 rear front propshaft use 6010
00-11 rear front propshaft use 6008
97-11 rear rear propshaft use 6008
Old May 28, 2014 | 01:26 PM
dr_whigham's Avatar
dr_whigham
So there's 3 bearings or 2?
Old May 28, 2014 | 04:05 PM
LoneStarFRC's Avatar
LoneStarFRC
3 bearings, 1 in front and 2 in rear.
Old May 28, 2014 | 04:36 PM
bj1k's Avatar
bj1k
We have a local bearing company that has bearings for everything. All you need is the old bearing or bearing numbers and they can match it up.
Old May 28, 2014 | 07:15 PM
dr_whigham's Avatar
dr_whigham
So (1) 6007 and (2) 6008's and that's all I'd need? Sorry for making this redundant, but maybe my elementary questions will help someone else along the way...
Old May 28, 2014 | 10:46 PM
o1Z0sick's Avatar
o1Z0sick
Correct and i found some upgraded SKF bearings if you would like to know what they are send me a pm. A little more expensive but harder and stronger steel so they have a higher rpm/load rating.
Old Jan 8, 2018 | 03:24 PM
Dman427's Avatar
Dman427
yes I would like to know what they are what are the part Numbers of the upgraded SKF ??
Old Jan 9, 2018 | 10:16 AM
slow_pokeC5's Avatar
slow_pokeC5
i have been racing oval track stuff for a few years up here in CT and always use off the shelf Timken bearings. I've got Timken stuff that I got right from NAPA in everything in the car for 3 years now and haven't had to replace a single bearing with thousands of hard laps on them.
Just go cross reference those SKF #s with Timken stuff and you will be mint for years.
To Torque tube bearings
