TPMS batteries
Old May 25, 2014 | 05:35 AM
1972bluelt1's Avatar
1972bluelt1
Default TPMS batteries
I have a 2001 C5 with just under 10k miles that has never had anything done to the TPMS sensors. What will happen when the batteries start to fail? No issues now, but I've read the batteries last 7-10 years, my car will be 14 in Dec.
Thank You,
Old May 25, 2014 | 06:58 AM
chuckeb84's Avatar
chuckeb84
Thank You,
Time for new tires?
You can replace them then
Old May 25, 2014 | 07:45 AM
65GGvert's Avatar
65GGvert
What will happen is when each battery dies, you will not get a display on the dash with that tire's pressure. That's all.
Old May 25, 2014 | 09:38 AM
JR-01's Avatar
JR-01
....and you will get a warning that your tire is flat and not to drive over 55.
Old May 25, 2014 | 10:07 AM
jrose7004's Avatar
jrose7004
They'll start reading XXX.
Old May 25, 2014 | 10:47 AM
65GGvert's Avatar
65GGvert
Disagree, it won't say it's flat because you'll get no signal from it. XXX will show on the dash. No warnings, no speed restriction.
Old May 25, 2014 | 11:00 AM
JR-01's Avatar
JR-01
Mine said tire was flat and not to drive over 55.
Old May 25, 2014 | 11:27 AM
jrose7004's Avatar
jrose7004
If I remembered correctly "Service Tire Monitoring System" was shown on the DIC and after I'd push reset, XXX would read for that tire.
Old May 25, 2014 | 11:43 AM
garllo's Avatar
garllo
I agree. That happened when I had my '98. At least the sensors after 2000 are cheaper than the early C5
Old May 25, 2014 | 11:56 AM
65GGvert's Avatar
65GGvert
That's what should happen with a bad battery.
Old May 26, 2014 | 12:31 AM
1972bluelt1
Thanks Guys,
The last time I bought tires for one of these, the tire place insisted on "rebuilding" the sensors. I came back when they said the work would be finished and watched the installer do nothing to the sensor of the last wheel.
For $5 a wheel, I knew it couldn't amount to much. When I told the salesman they hadn't touched the sensors, he said they could break the beads and do the rebuild (basically replace a seal), or refund the $20. I took the refund because I knew that wouldn't extend the life of the sensors.
I'll deal with it when it happens, just wanted to know what to expect.
Old May 26, 2014 | 12:40 AM
CactusCat's Avatar
CactusCat
Thanks Guys,
Good choice.
Old May 26, 2014 | 06:52 AM
1972bluelt1
Originally Posted by CactusCat
Good choice.
Yeah, I'm sure they would have caught it and refunded the $.
Old May 26, 2014 | 08:07 AM
65GGvert's Avatar
65GGvert
When they say "rebuild the sensor", they mean put an "o" ring on it.
Old May 26, 2014 | 08:15 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
That's what mine does
Old May 27, 2014 | 12:26 AM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
My C6 DIC told me my tire was flat about a month ago. I hit the reset button and the DIC went back to correct reading. Mine is an '05 and I plan to replace the tires and TPM batteries in the next month or so.
Is replacing the TPM batteries a difficult procedure once the old tires are removed?
What kind of batteries are in the TPMs?
Old May 27, 2014 | 12:58 AM
AngelDeath's Avatar
AngelDeath
Part 2, 3 & 4 are on the right and should be the first three.
Battery Part # BR2477A (Source DigiKey)
To TPMS batteries
Old May 27, 2014 | 01:02 AM
Dave68's Avatar
Dave68
I believe most folks just have the whole thing replaced. A set of 4 with install runs about $240 if the tires are dismounted, specifically for replacing the sensors.
Old May 27, 2014 | 01:04 AM
Dave68's Avatar
Dave68
This is what happened to me, although for the last three weeks, that warning hasn't returned. Nonetheless, I am budgeting for the replacement of all 4 sensors.
Old May 27, 2014 | 07:56 AM
JR-01's Avatar
JR-01
Mine were half that and install was free when I put the new tires on. I agree you might as well replace the units. They are getting pretty old after all.
