Cold Air Intake
Old May 28, 2014 | 08:30 PM
Clancy209's Avatar
Clancy209
I purchased the Corvette C5 Airaid High Flow Air Filter AIRAID SynthaMax dry filter.
I don't see any performance changes, that would make me but another. No RWHP added. Engine temps are the same.
Old May 28, 2014 | 09:04 PM
wheelman1944's Avatar
wheelman1944
Default airaid cold air
Originally Posted by VettesGoneWild
I'm a first time Vette owner, bought March of this year. 2002 all stock 6spd manual, 50K miles, 1 owner. Had a 69 Chevelle SS396 when I was a kid and always dreamed of owning a Vette some day. Love my Vette, so much fun to drive! Considering Vararam intake. Would I need any retuning or changes along with that?
I put an Airaid system on my 02 ....awesome difference...price is really really good....advertised 23 h p increase...and it did make a huge difference..also went with Corsa Extreme exhaust...incredible sound at idle and parking lot speeds... Absolutely quite at road speeds...and wide open throttle is just an amazing sound....I'm so happy an you will be too....lol....that'll be $2.00 please...good luck
Old May 28, 2014 | 09:19 PM
IH8FORD's Avatar
IH8FORD
I just installed my vararam today. Fit and finish is maybe worst I've seen in aftermarket part but the thing does work. If you get one just take your time installing
Old May 28, 2014 | 09:21 PM
vetteguy8's Avatar
vetteguy8
This is my third C5, get the blackwing and never look back ! trust me !
Old May 28, 2014 | 09:28 PM
bikeriderga's Avatar
bikeriderga
Originally Posted by baxsom
If you are not going to get an intake that draws air from outside the engine bay they just do the zip tie mod.
^^^^^^^ THIS ^^^^^^^^
If you add any so called CAI that is not actually bringing cold air in outside the engine bay, you are just wasting your money. The only way any CAI is going to increase performance if by bringing cold air in. Bringing more engine bay air accomplishes nothing but money in a vendors till.
Old May 28, 2014 | 09:38 PM
PHIL MEMPHIS's Avatar
PHIL MEMPHIS
They all do pretty much the same thing except for the Vararam. I bought mine for the looks.
BBK Polished.
Old May 28, 2014 | 10:00 PM
olbear1962's Avatar
olbear1962
Originally Posted by Tar Heel
I have a Vararam and installed it myself. I've never had another system but know there can't be too many other cold air kits on the market that will give you as much fresh air as the Vararam. Yes, the fit and finish could be improved and it took longer than it should have but once you're done you're done and it's nice. Just be patient and know when it's installed you'll dramatically improve air flow over stock.
Scott
I like mine
Old May 28, 2014 | 10:01 PM
oh1vette's Avatar
oh1vette
Just supercharge it and don't worry about the intake!
Old May 28, 2014 | 10:27 PM
torchredmadness's Avatar
torchredmadness
I've always thought when you are trying to get more air into the engine you would also want to try and get more air out. So I figured you would want something other than a stock exhaust to get the most of a CAI. I would at least shoot for a cat back exhaust. Most makers of CAI tend to over exaggerate the HP gains when adding such devices on your car. Most claim 15 - 25 increase HP which is crazy. All you will notice is a different intake sound. I really don't think you'll notice any noticeable HP gains. Just my thoughts on CAI.
Old May 28, 2014 | 10:48 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Rolling with the VRB2 for years now, not gonna change out a great system. Everyone says the install is tough,,,get a Mustang,,,all that crap is snap on,,,,,,yeah right
VRB2 was worth 3 tenths at the track all by itself!
Old May 28, 2014 | 11:00 PM
striper's Avatar
striper
I also have a Callaway Honker and have had years of excellent satisfaction. Installation is not difficult either and it includes everything you need, even the right size drill bit. It's not expensive compared to others when you factor in one thing. Almost every other intake does not include an air bridge, which if you decide to buy that also usually adds about a couple hundred bucks to any intake install. Add that up and you are at Honker price. The point is that the Honer eliminates this part because of its superior design. It does this by relocating the MAF to just in front of the throttle body, as GM did when they went from C5 to C6. Callaway did this first. The air makes a much smoother flow from the intake to the engine this way. BTW, servicing is super easy too. IMO, worth every penny. I have had excellent service dealing direct with Callaway.
Old May 28, 2014 | 11:06 PM
Mylek's Avatar
Mylek
The computer usually adjusts within about 40mi after install. But I have heard of some folks needing a tweek.
The VaraRam is the best performing unit IMO. However, I agree the installation is a pain. I recomend having it installed. That way, if you need a bit of a tweek in tuning, they'll already have it and and be able to tune it at the same time. Not to mention not a lot of down time.
Old May 28, 2014 | 11:13 PM
  #33
bikeriderga
It is true the more air in, the more air out.
If you do change exhaust with the Vararam, you will probably need a tune.. My Z06 would throw lean codes with just the Vararam, XPipe, and Corsa Extremes.
Old May 28, 2014 | 11:35 PM
  #34
jornahow's Avatar
jornahow
If you appreciate good design, engineering and construction this is the one to get ... unless you drank the kool-aid.
Old May 28, 2014 | 11:39 PM
  #35
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I agree. I love my Honker!
Old May 28, 2014 | 11:55 PM
  #36
F&Yb0dluvr's Avatar
F&Yb0dluvr
Whatever intake you decide on definitely remove the fog light covers to let more air in(if you get a vararam you gave to do that)
Old May 29, 2014 | 07:12 AM
  #37
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Callaway Honker, B&B Tri-flow cat back and dyno tune = about 25rwhp
http://forums.corvetteforum.com/perf...dyno-tune.html
To Cold Air Intake
Old Jul 5, 2014 | 10:57 AM
  #38
Mickster144's Avatar
Mickster144
I already have cam,headers and exhaust mod's, so my question is two fold. One, I replaced the air filter and now the hold down clamp pops off. I can't see spending a lot of money on a CAI Aftermarket system to gain HP, which I am doubtful I would notice any. I do like the looks of the aftermarket ones, so which one would you guys recommend? Carbon fiber?
Old Jul 5, 2014 | 11:38 AM
  #39
SVT_Z06's Avatar
SVT_Z06
Is there any other intake that has been proven to perform better than the Vararam once you're moving?
Out of all the intakes stated in this thread......what intake will get you the coldest air possible ONCE you're moving?
I think you guys get my point.
Having the best fit and finish does not necessarily mean you'll get the best performance. Function over finish....IMO.
Old Jul 5, 2014 | 12:12 PM
  #40
Water_Walker's Avatar
Water_Walker
Originally Posted by zagger
First off lets address CAI and what it does aside of making more noise which is sometimes mistaken for increase in performance. The stock system flows pretty well, actually it's good for 450+hp which is way above the stock LS1 or 6 need. So if flow is not the problem than it must be air density. Cold air being more dense and thus caring more oxygen allowing for better fuel mixture burn. Any intake taking air from under the hood is rendered equal in that respect considering the MAS and TB flow capability. So the amount of air the engine gets is limited by those two not the filter size which in all cases exceeds the real need. VR claims to also produce ram air effect, kind of like a small FI system at higher speeds thus forcing even more cooler/denser air past the MAF and TB normal limit. That point has been argued to death here on CF but they have track data to back them up. Not HP data but quicker track times which calculate to real HP gains. Vararam and Honker on principal breathe outside/colder air and will give the best gains out of all the rest. Not the 23+ HP gains but should be just north of 10. If you read up on the subject you are already aware of the VR issues and the cost of the Honker. In real world the gains are very marginal at best on stock set up's. The computer in our cars is pretty smart and quickly adjust so as to bring the motor to original working specs deemed best for you by the factory and EPA. You want a bang for your buck, get it dyno tuned. No bolt on intake will match the gain of a good tune which can be had for little more than Vararam and about same cost as a Honker. Even an inexpensive mail order tune will wake the car more than just an intake. Just my .02
Some good advice here.
Honker all the way because of the quality and design.
