[Z06] Right front amber light needs replacement?
Old Jun 20, 2014 | 05:13 PM
bjones7131's Avatar
bjones7131
Same process, most likely if your signal is blinking really fast is the result of bad bulb
Old Jun 20, 2014 | 05:14 PM
6SpeedTA95's Avatar
6SpeedTA95
Definitely looks like a bad bulb...good to know it's the same process. Do you happen to know if it's the same bulb? If not, no big deal I'll grab one from autozone.
Old Jun 20, 2014 | 05:59 PM
bjones7131's Avatar
bjones7131
My bulb was a 4157 sylvania, from napa $4.34. When u pull bulb out it will have the number on it,4135 and any parts store will have it
Old Jun 20, 2014 | 07:34 PM
JETninja's Avatar
JETninja
WA Events Coordinator
I replaced 11 of the lights all around the car with these LED's. Do a search at the auction site for: T10 194 168 501 W5W 20 SMD LED Car Side Wedge Light Bulb Lamp 12V White
Been in the car for 2yrs, not an issue.
LED's last longer, run cooler, use 1/10th the power, and light up much faster than stock incandescents.
