dumb question and dont mean to thread jack but has anyone ever replaced it with an led? just curious if it could be done
I haven't tried and I don't know why you would want to. It's only visible at night and if you make it brighter, it will be distracting. You can't turn it off unless you also add a switch. You've got the map lights if you want a bright light shining on your console at night. Are you thinking of some other color of "mood" light?
I checked my '01 and I couldn't find it. I'll have to see if it's burnt out. How hard is it to change to LED? Can you just pop a new bulb in or do you have to wire it up?
The only way I can tell if mine is working is to start the car in the garage and hold my hand up under the mirror.
That said, I'm not sure I'd want it any brighter than it is now anyway...it may be useless, but at least it's not annoying.
If you want an LED there, the good news is, it is an LED already.
If you want it brighter or a different color, the bad news is, it's hardwired into the mirror, not socketed, and there's no procedure in the FSM to replace it.
