Service Column Lock
Old Jun 5, 2014 | 04:56 PM
hb4lthr's Avatar
hb4lthr
Default Service Column Lock
I have a 2004 Commemorative Z06 with 20K miles. It is predominantly a garage queen. Today I decided to take it out for a spin. As soon as I started the car, the odometer flashed up the mileage and within 2 seconds the message "service column lock" appeared on the DIC. I then hit the reset button and the odometer was displayed once again. I drove to the gym finished my work out and started the car and the same error message came up again. I decided to look at the owners manual but the only advise was to have the system serviced so I have an appointment at the dealer where I bought the car to have it serviced early next week.
I was hoping that someone on this forum may have experienced a similar issue such as needing to refill the power steering fluid or something easy that I can do vs takinging it to the dealer.
Any ideas will be greatly appreciated.
Old Jun 5, 2014 | 05:08 PM
Phanni's Avatar
Phanni
One major cause of "service column lock" errors is a weak battery.
since you say your car is a 'garage queen' it's likely that is the issue, however, any C-5 owner that does not have some sort of after market fix for the column lock problem is only tempting fate. The Lmcs or column lock bypass fix is a must IMNSHO.
Old Jun 5, 2014 | 06:03 PM
hb4lthr's Avatar
hb4lthr
Old Jun 5, 2014 | 06:05 PM
hb4lthr's Avatar
hb4lthr
Originally Posted by 8VETTE7
Google "Compliance Parts' without the quotes. Read about and then order and install an LMC5. Dealer is going to bend you over BIG TIME. Bring a big tube of KY if you keep the appointment at the Stealership.
Read about a 2003 with the same issue:
http://forums.corvetteforum.com/c5-g...-c5-vette.html
Thanks. I did go to www.complianceparts.com and saw that these items only cost $40. How easy is it to install?
However my steering wheel functions fine. It is not locking up like the others on the link you've provided.
Old Jun 5, 2014 | 06:08 PM
hb4lthr's Avatar
hb4lthr
one more question. Even though my steering wheel does not lock up is it at risk to do so until I fix it?
Old Jun 5, 2014 | 06:31 PM
Rush Fan's Avatar
Rush Fan
I had that happen to my car. The error message came up so I drove it to the dealer. They "fixed" it. One day next week at work, I got the message again as I was leaving. I couldn't clear it and if I put the car in gear, I could drive about 5'.
I called the dealer and told them what happened. They sent a tow truck at their expense and that's how I got home that night.
Old Jun 5, 2014 | 06:51 PM
tlove32's Avatar
tlove32
EVERYONE READ THE ABOVE MESSAGE!!!!! The dealership does not have a fix or a workaround. Their so-called fix has failed repeatedly. There are only 2 fixes....LMC5 and The Column-Lock Bypass.
The
Old Jun 5, 2014 | 07:14 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Yes
As stated earlier, a weak battery is the cause of most of these issues. If you have a battery charger at home, I'd recommend you charge it up overnight. Read that article - lots of info there.
I installed the LMC5 on my car
Old Jun 5, 2014 | 07:30 PM
zagger's Avatar
zagger
It blows my mind that some people still live in denial and don't correct the problem before it disables their car.
Old Jun 5, 2014 | 08:17 PM
hb4lthr's Avatar
hb4lthr
As stated above the answer is yes.
Without more specific inspection I can only guess that what has happened to your car is that the Column Lock Relay fried with the lock pin in the retracted position. It is a moot point what the detail is at this point unless you want the Stealership to charge you upwards of $1000 or more for a fix that will fail. GM does not now or has ever had a permanent fix for the Column Lock problem. Only EXPENSIVE band aids.
Get and install an LMC5. There is a video out there on the internet about installing it. Google "LMC5 install video" without the quotes should find it.
As noted above, the MOST likely cause of your problem started with a weak or bad battery or loose or corroded battery cables including at the starter. If it were my car that is the first thing I would be checking out/ correcting while I waited for the LMC5 to arrive.
Thanks. I just watched that video and the install seems pretty straightforward. I appreciate everyone's help.
Old Jun 5, 2014 | 08:40 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Caution!!!! Just a month or so ago I did the same as you. Took my laptop in the garage and followed the video. The second I started the car the column locked!!
Read the directions that come with the LMC5 as it has you pull a fuse before you start that is not shown in the video!!
Good Luck!!
Old Jun 5, 2014 | 08:47 PM
hb4lthr's Avatar
hb4lthr
Good Luck!!
...aha!!! Thanks for this additional tip
Old Jun 5, 2014 | 08:49 PM
Jeff T.'s Avatar
Jeff T.
It was Sunday and it freaked me out! No need for someone else to feel that pain!!
Old Jun 5, 2014 | 08:54 PM
hb4lthr's Avatar
hb4lthr
And I appreciate it Sir
Old Jun 5, 2014 | 10:16 PM
o2bnkc's Avatar
o2bnkc
It may already have been worked on at the dealer because it doesn't lock up. That is one sign that an attempt has been made to put the dealership band aid on it. I'm just curious. You've been a member since 2008 and you're new to this problem?
Old Jun 6, 2014 | 05:06 AM
hb4lthr's Avatar
hb4lthr
Correct. What can I say? Does anyone know if this part is available locally rather than having to wait for the part to arrive by mail? Now that I know the fix I'd like to get it done this weekend if possible. I live in Maryland.
Old Jun 6, 2014 | 07:54 AM
dadaroo's Avatar
dadaroo
No, you need to order it.
To Service Column Lock
Old Jun 6, 2014 | 10:01 AM
Gjd's Avatar
Gjd
Just installed one on mine. Ordered on Saturday got it on Wednesday. Only took about 30 minutes to install and now all is right.
Old Mar 19, 2021 | 09:28 AM
hb4lthr's Avatar
hb4lthr
Hello All,
Sorry to rehash an old issue. Back in 2014 I had installed the LMC5 to get rid of the Service Column Lock error code on the dash. Since then, that message has not appeared again. Recently I hadn't started it in a while and when I finally did, the Service Column Lock code appeared again. The first response to this thread was that this code might be appearing due to a weak battery. I had replaced my battery 3 years ago. Could the issue be that the battery needs replacing after 3 years or do you think it will eventually go away if I drive the car more frequently? Or could it be something else?
Old Mar 19, 2021 | 10:04 AM
BKbroiler's Avatar
BKbroiler
A brand new battery will eventually be drained significantly over time in a C5. There are a number of things that draw current continuously even while the car is not in use. You need to charge your battery occasionally while the car is not in use.
