Cam Suggestions
Old Jun 16, 2014 | 10:02 PM
eddie gold's Avatar
eddie gold
Default Cam Suggestions
Looking for a little more, car is 2000 A4. Driven little some basic mods done. Borla, Air Intake, Shift Kit .Should I be looking to change anything else while doing a cam change? Thanks
Old Jun 17, 2014 | 08:32 AM
sfc rick's Avatar
sfc rick
Depending on how big a cam, you'll need to upgrade your Torque Convertor. While your cam is out replace your harmonic balancer and pin it. Replace your powersteering pump and altenator bracket with the better beefier one GM switched to in later years. In case you get the supercharger bug. Then everything that's required for one is already done for you so you don't have to tear into it again.
Just a suggestion.....
