Headlamp adjustment tool question
Old Jun 17, 2014 | 02:31 PM
c6miller's Avatar
c6miller
Default Headlamp adjustment tool question
What star size sockets will I need to adjust the headlights. I see one is for up/down and the other left/right but not clear on which one does what. Appreciate the help.
Old Jun 17, 2014 | 03:21 PM
Lee DeRaud's Avatar
Lee DeRaud
Odd little widget, innit? I have no idea what weird inverted Torx thingie fits over the outside, but the hole in the middle of the adjuster takes a standard T15 bit.
The one directly behind the plug is horizontal, the one below it is vertical.
Old Jun 18, 2014 | 02:39 AM
GenerationX1's Avatar
GenerationX1
Try 1/4 inch socket or a 7mm socket. I think I used one of those 2 with an extension.
Old Jun 18, 2014 | 05:05 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Be very careful when adjusting. They break easy, and you can buy just the adjusting rod.
Old Jun 18, 2014 | 09:25 AM
seu318's Avatar
seu318
I just had to do one of mine - my state inspection indicated it was pointing too low and to much to one side. I opened the headlights - carefully put a little penetrating oil on the adjustment rods - and the next day - with a 1/4 socket on an extension - very ginergly turned a quarter turn to loosen, then 1/4 turn back to tighten just to work the adjustment rods - then a couple more - moving to 1/2 turn in and 1/2 turn out, etc - until I was confident (as confident as I could be) that the rods would not bind up. Then I made my adjustments. It is scary when you get a look at how long and thin that one adjuster is - knowing that to break it means a new headlamp bucket. Just be careful, as already stated by someone.
Old Jun 18, 2014 | 09:54 AM
DeeGee's Avatar
DeeGee
Does this help? I posted this a few years ago.
Aiming Stock Headlights
Preparation
Chose a white wall to project the lights onto
Mark a vertical centreline on the screen in line with the center of the car (black tape?)
(look over the roof of the car to get the line)
Measure the height from the floor to the center of the headlight capsule
Mark a horizontal aiming line on the screen
Measure the distance between the centreline of the right headlight module and the center of the left headlight module.
Position the vertical tapes this distance to the right and left of the screen centreline
Lubricate the adjustment screws before adjusting See Note
Adjustments
Raise the hood
Raise the headlights
Remove the headlamp adjustment screw plug
Turn on the low beam headlights and block the light from projecting onto the screen from the passenger headlight
Check the horizontal aim
Adjust the horizontal aim adjusting screw to align the left edge of the high intensity zone with the headlight vertical centreline
The left edge of the beam should lie within 4” to the left and 4” to the right
of the vertical centreline.
Check the vertical aim
Adjust the vertical aim adjusting screw to align the top edge of the high intensity zone with the headlight horizontal centreline
The left edge of the beam should lie within 2” above and 2.5” below the lamp horizontal centreline.
Reinstall the headlamp adjustment screw plug
Repeat for the other headlight
Turn off the lights and close the hood
This is the pattern you're looking for
Advice Frome LonestarFRC:
Lubrication may not be enough. The problem is that the spray can't actually penetrate to where it's needed. There's a little internal gear-drive mechanism involved.
Important! If you attempt to make any adjustments, especially one involving the up/down adjuster and it doesn't move, or you meet a lot of resistance, stop right there. Do NOT attempt to force things. You will ABSOLUTELY break the long "goldenrod' (gold colored rod about 3" long). This is not an "if" or "maybe". Do NOT force it by twisting your wrench/nut-driver harder and harder. Once broken, these pieces are NOT available as a separate repair piece from GM. They will only sell you the entire headlight assembly.
If yours are frozen up, do a search on this issue. Many many posts about it. "Goldenrods" is one if the terms that may be helpful when doing a search. There IS a way to unfreeze the gear-drive mechanism but it involves removal of the headlight assembly to get access.
(Thanks to Junkman2008 for the picture)
Old Mar 26, 2015 | 02:27 PM
Fast Red's Avatar
Fast Red
Default Golden rod a fix
Preparation
Adjustments
Raise the hood
Here is something I found out. I had the golden rod problem in the stock headlights after not liking the Apex projectors which a former owner had put it. They were out of adjustment so bad that you could not see. I golden rods were froze. The P B Blaster didnt work and I broke one off. With nothing to loose I took the light golden rod gear box a part. It just snaps together. With the gear that is froze on the shaft out, you can work it loose. I never have seen on the forum that you can take them apart and fix them. With the broken shaft, I just cut a slot in the shaft end for a screw driver after I had it all loosened up. Now they both adjust. Took the other apart and fixed it too.
Old Mar 26, 2015 | 08:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Preparation
Adjustments
Raise the hood
Nice instructions !!!!!!
Old Mar 26, 2015 | 08:31 PM
73Corvette's Avatar
73Corvette
[QUOTE=DeeGee;1587161338]Does this help? I posted this a few years ago.
NICE job man...perfect. Copied and pasted to my C5 files...
Old Mar 26, 2015 | 11:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
[QUOTE=73Corvette;1589275288]
Ya man I do the same thing !!!!!!!!!!
Old Mar 27, 2015 | 02:13 PM
GenerationX1
I had to take all that apart just to replace the golden rod on mine. The shaft broke to far down to cut a slit in it to use a screwdriver. There is a thread somewhere about it on here that I went by to do it.
Old Mar 27, 2015 | 02:30 PM
Fast Red's Avatar
Fast Red
Default do people really understand?
I am full aware of how to aim headlights. The adjusting gear freezing up which I have seen no one post that you can just take it apart and free it. Been doing this over 50 yrs and only trying to fill in the hole on a fix that is the best and not that hard. Hope all the headlight aiming will help someone. I know most people have no idea on how to aim the headlights. I don't want my state to be like Caif. They have to take the cars in for emissions and they check brakes , lights and other stuff where I feel you are treated like an idiot.
Old Mar 29, 2015 | 03:19 PM
GenerationX1
Yeah I know what you mean. I also installed the fog lights from the base C5 Corvette on my C5 Z06.
Here is the link I went by. I thought at first I found it on here but it was the digital corvettes site I found my info from.
http://www.digitalcorvettes.com/foru...d.php?t=103322
Old Mar 29, 2015 | 03:35 PM
LoneStarFRC's Avatar
LoneStarFRC
For those interested, the correct socket that fits the adjuster rods are called "external Torx" sockets, which are configured the exact opposite of a regular "Torx" bit.
The sizes run the same as the regular Torx (which some people call "star" fasteners), except there is an "E" prefix, signifying "External".
Thus, a regular Torx bit of a size 20 is referred to as a "T20", and it's counterpart would be an "E20". You can either buy small inexpensive 1/4" drive socket sets, OR you can buy individual sockets of a particular size for the job. These are found at most all the popular AP stores.
HTH
Old Mar 29, 2015 | 11:22 PM
GenerationX1
HTH
Thank you Sir for that info.
I actually got away with using a long extension and a 1/4" socket to adjust mine.
Old Mar 30, 2015 | 09:22 AM
Phanni's Avatar
Phanni
Yes, they work just fine.
BTW be sure to lubricate the adjustment screws before trying this. The screw is non replaceable without buying the whole light assembly.
Old Jul 18, 2018 | 02:37 PM
J. Kent's Avatar
J. Kent
HTH
Thanks. What size?
To Headlamp adjustment tool question
Old Jul 18, 2018 | 05:29 PM
calguy's Avatar
calguy
When I installed my led lights I did exactly as you.
Extremely cautious with those first one or two turns of the adjusting rods.
Even though they no longer need to be adjusted, I spray them with blaster every three months, just to keep them operational, if the time ever comes I need to adjust them again.
Bob.
Old Jul 19, 2018 | 10:27 AM
Clancy209's Avatar
Clancy209
1/4, 12 point socket works OK, AS THOSE BEFORE SAID SPRAY THEM DOWN, LET THEM SIT, THEY ARE FRAGILE.
Old Jul 19, 2018 | 03:14 PM
J. Kent's Avatar
J. Kent
OK. Picked up a set of Evternal Torx sockets. Used trial & error to find the correct size: It's E8
