Tpms
Old Jun 25, 2014 | 11:07 AM
HERK's Avatar
HERK
Default Tpms
I bought a set of HRE wheels used and the TPMS are glued to the inside of each wheel. Is that right ? Thanks
Old Jun 25, 2014 | 12:02 PM
JR-01's Avatar
JR-01
no.
Old Jun 25, 2014 | 02:51 PM
dataporter's Avatar
dataporter
If the wheel is not designed to have the C5 TPMS installed in the valve stem hole, then people epoxy or band them or both to the inside of the barrel if they want the TPMS system to work.
Old Jun 25, 2014 | 03:13 PM
JR-01's Avatar
JR-01
That sounds like a failure waiting to happen. Does it work?
Old Jun 25, 2014 | 03:41 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Yes, it can and does work. Why wouldn't it? You don't have to put air in your tires through the TPMS to make it work.
Old Jun 25, 2014 | 04:06 PM
Lee DeRaud's Avatar
Lee DeRaud
I'm not sure what you mean by "banding", but I wouldn't trust epoxy (or any other adhesive) in that environment long-term.
And I imagine having a sensor come adrift would be...exciting.
Old Jun 25, 2014 | 04:13 PM
HERK's Avatar
HERK
Thanks for the info guys.
Old Jun 25, 2014 | 04:15 PM
SG Lou's Avatar
SG Lou
The banded TPM sensor is a sensor that is secured to the rim well with a worm-drive band clamp.
Old Jun 25, 2014 | 04:22 PM
REDHOTS's Avatar
REDHOTS
If it was glued well, you probably couldn't take it off if you wanted too without wrecking it.
The bands are not cheap, and a pain anyway. If it did fall off you might hear it at slow speeds, and when moving it will just be stuck to the tire until you stop. Would also feel vibrations come and go too. Seen a lot of installers break the band removing, or worse install the tire and not even know they broke it. There are quite a few wheels that a valve mounted sensor wouldn't fit.
Old Jun 25, 2014 | 04:56 PM
thisMSGgood4me
Yes, a TPMS installed through the valve stem hole is obviously the best solution for the installation but that's not possible with some wheels, so one has to come up with some other solution. While not as desirable, these other solutions can and do work.
Old Jun 25, 2014 | 05:16 PM
Lee DeRaud's Avatar
Lee DeRaud
I can see where the "and glue" comes in: I'd want something to keep the whole thing from slipping around and throwing the wheel out of balance.
Old Jun 25, 2014 | 07:38 PM
ezrider4u2's Avatar
ezrider4u2
I had mine done this way when I went aftermarket and they work just fine. They had been banded previously but the bands in the rear wheels failed and the tpms went around and around causing tire damage.
To Tpms
