Brakes not right
Old Jul 8, 2014 | 04:29 PM
Birdman69's Avatar
Birdman69
5th Gear
Default Brakes not right
Hi Guys,
My brakes are not acting right. The pedal has a lot of travel and I'm losing fluid. I checked and it seems I have a leak between the MC and the booster. Is swapping the MC a DIY job or best left to a shop?
I do most work myself but have never changed a MC. I am worried about getting all the air out. Should I try to replace it myself? How best to remove all the air from the MC? I know I will need to bleed each wheel after in get the new MC in. Thanks for any help.
Old Jul 8, 2014 | 04:36 PM
Phanni's Avatar
Phanni
It isn't that big of a job.
Once you replace the MC, fill it, then do the brake bleeding as required. Keep the MC full (you'll need to do it pretty often at the start.) It's really a good idea to do a fluid change every so often anyhow. I do mine every two years.
