Short dip sticked ?
Old Jul 8, 2014 | 08:11 PM
w2rivers's Avatar
w2rivers
Default Short dip sticked ?
I just changed oil for the first time in my new used 2001 Zo6. I put in the recommended 6.5 quarts but the dip stick shows I'm one quart low? I haven't measured the stick (how long should it be) but it is in a twisted condition. Could it have been messed with or?????? I'm not going to add more until I hear from someone about this.
Old Jul 8, 2014 | 08:31 PM
GTJim's Avatar
GTJim
Oh God, can't wait to read some of the responses to this thread
Not making fun of you OP, just the thread title
Old Jul 8, 2014 | 08:36 PM
w2rivers's Avatar
w2rivers
Sorry sometimes I just can't help myself when I see an opportunity. and it is a real question. I may be shorting the quantity even though I put in the stated amount.
Old Jul 8, 2014 | 08:48 PM
GTJim's Avatar
GTJim
Did you start the car and let the oil pressure build up? I'd run it for a min or two and then check it again.
Lee DeRaud's Avatar
Lee DeRaud
You wouldn't believe how long mine is.
All seriousness aside...I've got a 2004 LS1, but I doubt there's a difference in the dipstick tube length.
The "corkscrew" thing is normal. Just measuring the actual silver part of the stick, it's 23-13/16" to the top (full) hole, 24-5/16" to the bottom (quart low?) hole. (Add another 1/2" if you're including the yellow plug portion with the o-ring.)
Old Jul 8, 2014 | 08:57 PM
bluestreak63's Avatar
bluestreak63
Are you sure you put in 6.5 quarts and not 5.5? Not saying you don't know how to count, but maybe got sidetracked or something while putting the oil in?
Old Jul 8, 2014 | 11:08 PM
If you indeed put 6.5 quarts in the car, then I don't see any way it would read a full quart low. Some owners have reported that with 6.5 quarts in it may read about a 1/2 quart low, but that seems to be the exception rather than the rule. I know on my '03, 6.5 quarts hits the full mark right on the spot.
Old Jul 8, 2014 | 11:13 PM
w2rivers's Avatar
w2rivers
Yep, 6.5 quarts and my dip stick is as it should be. Lol Beginning to think I can't see such clear oil. Going to check it in morning before starting. I appreciate all the advice.
Old Jul 9, 2014 | 12:34 AM
Lee DeRaud's Avatar
Lee DeRaud
If you're used to 'dead dinosaur' oil and don't have great lighting in your garage, the first time or two checking can be misleading.
Old Jul 9, 2014 | 03:40 AM
stu12dozen's Avatar
stu12dozen
If it still registers low, then add a bit. And always remember, "it's not how long it is, it's how you use it"!
Sorry, the devil made me do it!
Old Jul 9, 2014 | 10:34 AM
aaronc7's Avatar
aaronc7
Mine took closer to 7 to reach the full mark. Probably depends on how long you let it drain, the angle the car is at on the jack stands/lift.
I drain the oil out of the pan until it's no longer a steady stream and then replace the drain plug hand-tight. Next, I replace the oil filter (I prefill the new one with clean oil). I then remove the oil pan drain plug and let it drain until it's no longer stead stream, again (a good bit more comes out.... at least it makes me feel better ). Next, I put in around 6-6.5 quarts (When I start to see it registering on the dipstick I call that good) and start the car up, let it idle for a few mins, then shut it down. Check for any leaks, then put the car back on flat/level ground. By that time the oil has had plenty of time to drain back to the pan, so I check oil level again and add as necessary to full mark.
Old Jul 9, 2014 | 10:40 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
My 2001 Coupe has always taken a FULL 7 quarts to top off. I believe you have the same issue.
Old Jul 9, 2014 | 12:22 PM
NatB's Avatar
NatB
I hear there is a little blue pill that helps
Old Jul 9, 2014 | 12:44 PM
C5Txfan's Avatar
C5Txfan
That'll just untwist the stick .. not make it longer ..
Old Jul 9, 2014 | 01:22 PM
Black 02's Avatar
Black 02
I am happy with my dip stick. Does a satisfactory job of checking the oil
Old Jul 9, 2014 | 01:34 PM
ZigZag's Avatar
ZigZag
My wife got a vanity plate "SMALL 1". She said is wasn't any reflection on me.
Old Jul 9, 2014 | 01:48 PM
C5Txfan's Avatar
C5Txfan
If it's for her car maybe she's referring to her ... uuuh ... never mind !
To Short dip sticked ?
Old Jul 9, 2014 | 02:20 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Okay, I waited two days before posting this. (Okay.....it felt like two days!!) I think I have exercised the proper amount of restraint, so here goes!!!
Short dip-sticked??????? That's how my ex used to say she felt every time after we had sex!!!!!
DSTURBD
Old Jul 9, 2014 | 02:32 PM
Black 02's Avatar
Black 02
DSTURBD
I'm sorry. Keep your head up bro
Old Jul 9, 2014 | 04:41 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
My dip stick reads a whole lot deeper now that I "Plasti Dipped" it BLACK.
