Broken down c5 please help. Electrical
Old Jul 10, 2014 | 04:17 PM
wardamncorvette's Avatar
wardamncorvette
St. Jude Donor '14-'15
Default Broken down c5 please help. Electrical
So I'm driving down the road headed back to my house and I notice my radio speakers go out? So I'm thinking that's weird must be a ground or something.
So I keep driving and my speedo, gas gauge, battery gauges start going ape sh*t. They stopped working completely then would bounce to 200mph (and all other max) then stop. Nothing was working electrical at all and then was nowhere to stop so I kept going. Finally found a store (as soon as my engine cut off) and was able to coast in to a spot where I'm at right now. And now when I try to start car I get the clicking dead battery sound.
Wtf.
Sounds like alternator to me..?
My friend is on the way with a voltage meter to see what's up.
Any help is greatly appreciated.
-also I did get a low voltage message earlier today on my car. I didn't crank it last 2 days so I thought that's what it was.
Old Jul 10, 2014 | 04:30 PM
wardamncorvette
Originally Posted by 8VETTE7
Bet that is what it is...... DEAD battery. Common problem in the heat of summer.
Thought the battery was only used primarily to start the car?
Once started everything runs mostly off alternator?
Old Jul 10, 2014 | 04:41 PM
Daddyrama31's Avatar
Daddyrama31
Classic signs of a toasted battery! Keep us posted!
wardamncorvette
Originally Posted by Daddyrama31
Your battery is most likely toasted!
I really hope so rather it be battery than a lot of other things..
Old Jul 10, 2014 | 04:43 PM
3boystoys's Avatar
3boystoys
Not really, the battery helps to even things out at low rpm's and acts as a load to the alternator. A bad battery can kill an alternator and vice versa.
Old Jul 10, 2014 | 04:45 PM
Daddyrama31
Take it out. Check to see if you have any leaks underneath. If you do, than you may have a bigger problem. I would not worry though, these cars seem to have a lot of parasitic draw on the battery. Lot's of folks use a trickle charger to keep the battery charged and counteract the draw. You can get one at Walmart for 20 bucks and they are a great investment.
wardamncorvette
Ok well I'm going to get a battery..
Btw guys here's a good promo code for advance auto parts..
TRT41 40$ off 100$
TRT30 30% off any online order
In store pickup too. No tax
Old Jul 10, 2014 | 04:55 PM
chuckeb84's Avatar
chuckeb84
TRT41 40$ off 100$
Have them test the old battery..
Old Jul 10, 2014 | 05:13 PM
shift_oversteer's Avatar
shift_oversteer
He's going to read that too late hopefully it was the battery
Old Jul 10, 2014 | 05:16 PM
wardamncorvette
Volt reader said battery was at 8.5 volts. After jumped off went back up to 13.
Battery is the issue.
On the way to buy a new one now.
Noticed there was one bolt at the very bottom to remove the battery. Should be pretty simple although it is a corvette
Old Jul 10, 2014 | 05:20 PM
shift_oversteer
Good deal. I've had a few electrical gremlins myself in my short C5 ownership
Old Jul 10, 2014 | 05:21 PM
wardamncorvette
Today is the 31st day of my c5 ownership.
Old Jul 10, 2014 | 05:26 PM
chuckeb84's Avatar
chuckeb84
Check for an acid leak.
And look down there under the tray for acid damage...
When you get a chance..
Now how old are your tires??
Old Jul 10, 2014 | 05:29 PM
wardamncorvette
Tires are great
Old Jul 10, 2014 | 05:41 PM
wardamncorvette
What battery size is recommended?
75, 650 cca
78, 700 cca
75-3, 700 cca
75 690 ca
Old Jul 10, 2014 | 06:58 PM
Daddyrama31
75, 650 cca
78, 700 cca
75-3, 700 cca
75 690 ca
Optima Red or Yellow top's are good choices. 78 series, 700 cca
Old Jul 10, 2014 | 07:08 PM
wardamncorvette
Ok I got the battery removed... If I give it to advance I save 18.00 core charge. Gonna end up costing about 68$ for new battery. If I get the 109$ one. Not sure but prolly going with the 116.99 one.
Below is a pic of under battery tray. Doesn't look bad
To Broken down c5 please help. Electrical
Old Jul 10, 2014 | 07:18 PM
Daddyrama31
Old Jul 10, 2014 | 07:20 PM
ZigZag's Avatar
ZigZag
Get the best one you can afford and with the most CCA and reserve power.
Old Jul 10, 2014 | 08:44 PM
wardamncorvette
All is well guys..
Thanks for your help!
Got the vette home and is running great.
Got the 700cca battery for 81$ after tax
